Offset Question
Old Dec 1, 2012 | 12:22 AM
josephx66's Avatar
josephx66
Default Offset Question
What offset do I need to make 9 inch wheels flush with the fender. THanks!
Old Dec 1, 2012 | 06:37 PM
josephx66's Avatar
josephx66
Anybody? most people run 9.5 or 10 inch rims. I cant find any info on 9inch width rims
Old Dec 1, 2012 | 06:49 PM
MyIS350G's Avatar
MyIS350G
need more info, stock height, drop on springs, coils..
ex: 19x9 +20 stock height is not the same as 19x9+20 with springs, same with coils..
Old Dec 1, 2012 | 07:13 PM
Slammer1's Avatar
Slammer1
I am curious on this one too. I am running 18s and looking to go with 18x9s on the rear. I have read that a set offset will not necessarily work with any wheel. Seems it depends on the way that the spokes of the wheel are curved? Some wheels I have searched fit in a 45mm offset, but others don't . Very difficult topic for sure.
Old Dec 1, 2012 | 07:22 PM
heyarms's Avatar
heyarms
Y'all should search the forum as well as the Internet in general. Offset is not very complex, and there's plenty of info on the forum to find wheels that fit your criteria
Old Dec 1, 2012 | 07:25 PM
chase350's Avatar
chase350
Most wheel companies only make 9.5 not 9. Wider is always better. U could run a 9.5 in the front and 10.5 in the rear with a offset around 25 to 30 with out any problems. So if u run a 9 your offset should be around 20 to make it flush. I use to have a set of forgestar wheels and they can make whatever offset u what.
Old Dec 1, 2012 | 07:50 PM
projectdna's Avatar
projectdna
you know how there's always one post in a thread where there's more opinion than fact?...
firstly, most wheel companies can make whatever width a customer wants - as long as money isn't an issue. most wheel companies, however, do stick with standard wheel diameters and widths because they are either the easiest to sell, have the highest profit/cost ratio per wheel, and/or are the most popular size(s).
second, is wider better? there's a point of diminishing returns, because as the wheel width increases, the window of useable offsets decrease. on the outside, it's the wheel vs. the fender. on the inside, it's the wheel vs. suspension components. also, unsprung weight of wider wheels and tires actually bog down the car and possibly affect the car's handling negatively.
also, wider wheels are typically more expensive (albeit marginally) than their narrower counterparts. same goes for tires, assuming certain sizes and widths are actually manufactured/available.
btw, 9.5"/10.5" +25 or +30 will require some fender work, along with running narrower tire sizes. if the "will these wheels fit?" thread has taught the 2is community anything, it's that any flush fitment will require fender work.
Old Dec 1, 2012 | 08:03 PM
IS25Heaven's Avatar
IS25Heaven
google offset calculator. or read 2 pages of any fitment thread and you will find that you need.
Old Dec 1, 2012 | 10:08 PM
josephx66's Avatar
josephx66
well its just a 9inch wheel fsport drop. 235/35/19 tire im pretty sure. they have a 40 offset right now though as it stands.
Old Dec 1, 2012 | 10:09 PM
josephx66's Avatar
josephx66
im really just trying to figure out which size spacer to buy
Old Dec 1, 2012 | 10:29 PM
heyarms's Avatar
heyarms
don't own a tape measure?? Lol
Old Dec 1, 2012 | 10:30 PM
PlacidBoi's Avatar
PlacidBoi
I'm running 19x10 +35 dropped on Tein SS Coilovers, about 2inch drop from stock height. I am stretching 235/35/19 tires just so I dont scrape, but I haven't had any fender mods done to it.
Old Dec 2, 2012 | 05:11 AM
josephx66's Avatar
josephx66
No im just not sure where to measure from to get the best reading on what i need
Old Dec 2, 2012 | 06:12 AM
SCWB's Avatar
SCWB
19X9 +30 with 255/35/19 Pretty flush and No fender mod required.
Old Sep 5, 2019 | 04:39 PM
Mikes08's Avatar
Mikes08
Hi, guys I will be running ESR SR11's 18x8.5 (fronts) with 225/40/18 18x9.5 (rears) 255/40/18 I will be lowering my 08 IS250 in BC coil overs approximately 1.3inches in the front and 1.2 inches in the back. I just want to get rid of the fender gap I don't plan on slamming the car since this car will be driven for Auto X events, it will not be a daily driver. Will they fit ??
