antifreeze
Old Nov 12, 2012 | 05:44 PM
foe84's Avatar
foe84
Default antifreeze
I went to refill my windshield washer fluid today and noticed that my coolant looked to be a little low. I couldn't get a good look to see if the container stretched lower down or if there wasn't much coolant left. My car (2006 Is250 awe) has been staying 1/2 on the engine temperature gauge but need to get a closer look.
I bought prestone 50/50 (yellow bottle) just in case, but haven't opened it until i know its okay to use. My car has pink coolant and though the prestone claims its for all colors...i wanted to get someone opinion on this.
I could go to the toyota dealership and get pink, would it have to be flushed out still?
thanks
Old Nov 12, 2012 | 06:43 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
I would recommend getting Toyota coolant from either a Toyota or Lexus dealership. Keep in mind, the coolant level can fluctuate depending on if the car is hot or cold. As long as the level is in between the "low" and "full" lines, then you are ok. Be sure to check for any external leaks, mainly around the water pump area...
Old Nov 12, 2012 | 09:03 PM
Noeh's Avatar
Noeh
definitely get Toyota coolant
Old Nov 12, 2012 | 09:29 PM
KillaIS250's Avatar
KillaIS250
Get the pink Toyota coolant for sure! Don't mix it with the Prestone.
Old Nov 13, 2012 | 01:36 PM
Gville350's Avatar
Gville350
^Agreed! Spend the $20 and get the LONGLIFE coolant from Toyota/Lexus. Return that Prestone!
Old Nov 13, 2012 | 01:39 PM
edgeucated's Avatar
edgeucated
You can mix coolant but it will lower the life expectancy of both coolant.
Therefore only mix if you plan to flush your coolant soon, otherwise get toyota pink coolant
Old Nov 13, 2012 | 02:21 PM
drewster12's Avatar
drewster12
CL Folding 25,000
I believe that there are different pressure ratios with antifreeze. The yellow/green stuff produces higher pressure that can cause your radiator to leak. Buddy of mine put the yellow/green stuff in his VW and that is exactly what happened. Spend the $20 and save yourself the hassle.
Old Nov 13, 2012 | 03:49 PM
kickin8's Avatar
kickin8
2IS/2RX/4RX
get the Toyota pink.....
GS300ken
Oct 26, 2021 03:07 PM
vbb
IS F (2008-2014)
Mar 23, 2014 10:47 AM
ecfune
RX - 1st Gen (1999-2003)
Sep 18, 2013 05:47 AM
shikbas
Jan 11, 2008 05:18 PM
ontoy
Jun 18, 2006 10:06 AM
