Originally Posted by PlacidBoi
(Post 7553771)
Aren't FXR projector Bi-Xenon's? Cuz that's what I have retro'ed in my headlights right now.
^^^ any pics of the light output from behind the car? |
decided against the fxr. even though they are ideal they are too long. im still shopping around.... does anyone know if TRS gives discounts to people from different forums?
ordered d2s morimoto and philips bulbs. will update you guys on the project.
Originally Posted by rayac88
(Post 7562679)
Originally Posted by Hondadna4
(Post 7562896)
FOR YOUR FOGS!!! If so you think too big??? The reason why I picked the MH1 is because it has way better output than the D2S the only reason why I looked at the D2S was for OEM bulbs. The other issue I encounted was that the MH1 when adjusting it will touch the lense inside the holder. What I mean is Its long enough to adjust but to only a given amount. I hope those D2S are not longer because I think you will only have room to leave them in one place only. Send me a PM with all the detail of how its going and pics too. :D
since i have philips bulbs in my headlights and i have been too spoiled to put aftermarket bulbs in this project. you can beat the neatness of the light output on oem IMO. |
i am having issues getting the clip on the adjustment screw off so i can take the reflector out. any sugestions of how to take it out without breaking the black clip?
You must takke the reflector out by unscrewing it out all the way just keep on adjusting it and what will happen is there is two joint pieces that pop into black to pop those out there on the top of the reflector then keep unscrewing the adjustment knob and make sure its going outward and it will come out
http://i215.photobucket.com/albums/c...r6/photo-8.jpg
Theses two knobs on the top of the reflector. I would suggest you TRIPLE CHECK on the car the retro fit because they will ALWAYS NEED adjusting ALWAYS so just be very careful and before you permentiley mount them. FX's are awesome I want to retro fit them in my headlights but IDK its either those or RX's |
(Post 7563379)
Use a drill with a hex bit. Much faster.
got it i was trying to leave the clip on the back housing instead of on the reflector. i got it pop right out. now to just wait on the mailman today. then it will be me dremel and hurricane sandy.
DUDE cover your face withsomething man I breathed that stuff in and I was sick for a couple of days. You need to update this thread take pictures and post them. PLEASE!!!! I wanna see how this turns out
(Post 7563379)
(Post 7563492)
Retrofits never work as PLANNEDD !!! Dude get some heavy metal cutting discs from dremel your going to need the 5 pack the one with the quick release and just go crazy. I think that can keep some of the reflector bowl from the fog light. I think from there you can adjust a little
(Post 7563576)
