So winter + IS = ?
Old Oct 10, 2012 | 09:23 AM
reyoasian's Avatar
reyoasian
Originally Posted by Offspring
i refuse to drive it in winter due to all that salt and fear of rust.
rust proof + winter prep + coin wash + underbody spray and you're good to go for many years
Old Oct 10, 2012 | 11:43 AM
reyoasian's Avatar
reyoasian
Originally Posted by zydus
What about AWD...? I always thought LSD was mandatory for AWD cars
Old Oct 11, 2012 | 04:31 PM
p0lo8's Avatar
p0lo8
If it snows hard and they dont clean the streets fast enough then it is hard to drive, especially on turns, but manageable. When roads are clean no problem, and I use all-season tires (IS350 RWD). Did not put any salt or sand to the trunk last year but this year I probably will.
So it depends how good your area is at plowing the snow from the streets.
Old Oct 12, 2012 | 10:53 AM
L3XOTIC's Avatar
L3XOTIC
Yeah it'll be tough. Throw some dedicated Blizzak snow tires on there. If your in NJ... honestly should've just stuck to a IS250 AWD. Yes i know, less power, less fun, but hey.. your in a state that snows and gets cold more often then others. With dedicated winter tires and like a 200LB bag of salt, you will be okay, far from easy.
Old Oct 12, 2012 | 04:17 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
No 2IS models come with LSD except the 2010+ IS F.
(That is speaking of the rear differential, the AWD Transfer Case does have a Limited Slip Differential).
Jeff
Fleainat
Sep 25, 2012 05:25 PM
mitsuguy
Wheels, Tires & Brakes Forum
Dec 7, 2011 06:19 PM
KaiserSea1
Dec 11, 2009 04:22 AM
ping83
Dec 9, 2009 06:29 PM
sjgIS350
Feb 16, 2007 01:04 PM
