Headlights Adjustment sensor reset, is it possible?
i noticed a few days ago that my headlights were uneven. the driver side points a lot lower then the passenger side, and also seems to be tilting to the left side(not pointing straight). while my passenger side seems high up. i adjusted the rear sensor but it didn't seem to do anything. so i was wondering if it was possible to reset the AFS to like a default setting? I disconnect the negative battery cable and it still didn't seem to do anything also.
the driver side came lower than the passenger side for the safety, but I have the problem with the passenger side the cut off is title up to the right, I can not adjust to even cut off like my driver side? is it the way the Is headlights support to be?
I thought my headlights were all out of whack when I bought my car too, but the dealer checked them out when I brought it in for service and said that everything was correct and that's just how it is
driver side isnt really supposed to be lower. it's just the cutoff line of the HIDs are designed like that so you dont blink incoming traffic. just make sure both beams line up. the right and left beam should have the same cutoff line.
In US the driver side is lower so it does not blind oncoming traffic. I would like to know how to set it up to be even though because my let number did get nicked and it feels a little off.
are you talking about adjusting the height of the beam? there is a **** under the engine covers behind the headlights. there is a groove there so you can put your philip screwdriver in to adjust. just keep twisting and eventually it will adjust.
jniedens
Apr 22, 2009 04:41 AM
. Thanks!
