Who has gotten their front windows tinted?
I whent to get mines done, and they told
Me for the front ones I had to take off my door panels. Did you guys have to do that? Thanks
it is better to take off the door panel, becaude the tweeter pod is in the way and if you remove the panel then it will make for a better job and easier installation. door panel is easy to remove. just make sure they do a good job on the rear window! because if it has to be redone you will be in for a surprise ( defrost lines will be removed, even if a steamer is used) this applies to the IS models that i am aware of.
The shop that did my tint pulled the door panels. Just made it easier for them to deal with the tweeter pods sticking up. They did a great job, and you shouldn't be concerned about them pulling the door panels if they are a reputable shop. When i called my guy and told him the make and model, he already knew that the tweets stuck up and would be an issue. He had done IS's before....... Just a couple of screws hold the panels on anyway. Not a big deal at all.
