So installed the 2012 headlights today, (Sewell Version) . Everything worked out great, all I did was cut the green wire from the LEDs and wired them to the IGN.2 fuse. So that way I didn't have to turn the switch to get the LEDs to illuminate. My question is do you think it's possible to wire them to the power source of the original DRL's by using a DRL module from say V-led? As I'm sure you know the module steps up the voltage to 12volts therefore supplying full power to the LEDs. That way the LEDs will turn off when the headlights turn on. The LEDs are to bright at night for my taste, almost over powering the headlights. Some one chime in if you think this might work.. Thanks
