Air Filter Question
Old Jun 1, 2012 | 11:36 AM
vomer's Avatar
vomer
Exclamation Air Filter Question
Hi guys,
Just changed my engine air filter on my 08 is250 for the first time myself.
My only concern was that after replacing the filter I positioned the top part and put the clasps back on I noticed that the top cover is not flush with the bottom cover. What I mean is that there is a "lip" of sorts between the top and bottom covers. I stupidly did not check if this is how it normally is before I took it off so looking for input from you guys here.
If you run your finger around the joint of the two parts is there a lip?
The clasps went back on so I am assuming this means I did it right? Would you mind checking on yours to see if there is a lip between upper and lower?
Since this was the first time I have done this I was a bit concerned.
Thanks!
Old Jun 1, 2012 | 03:13 PM
skillvsluck's Avatar
skillvsluck
As long as all the clips snap into place, its should be closed properly
Old Jun 1, 2012 | 04:17 PM
vomer's Avatar
vomer
thanks for replying! Yes all of the clamps/clips went back on the way I took them off.
shikbas
Apr 1, 2016 09:53 PM
98023IS250
Mar 3, 2013 09:46 AM
Joeb427
Sep 2, 2007 06:50 PM
keviner808
May 4, 2007 03:27 AM
daryll40
Mar 31, 2006 10:47 PM
