What would you do first?
Old May 20, 2012 | 07:15 PM
Masciaman's Avatar
Masciaman
Default What would you do first?
If you were in my position with a bone stock 07 is350, would you either drop it on some coilovers or go for getting the wheels first?
Also, whats the widest wheel size i can go with if i was to go with 19'' wheels without having to roll or shave my fenders? Same with 20'' wheels how wide could i go without modding the fenders?
Old May 20, 2012 | 07:23 PM
laobo979's Avatar
laobo979
Go with the coilover first. Unless you find a hella deal on some set of wheels you really like. But the width all comes down to the offset and what work your will to put in.
Old May 20, 2012 | 07:30 PM
MyIS350G's Avatar
MyIS350G
coils for sure, if the offset is high enough you can event run 19x11
Old May 20, 2012 | 07:31 PM
SnowPeas's Avatar
SnowPeas
drop it for sure.
Old May 20, 2012 | 07:38 PM
Dr3wSaL's Avatar
Dr3wSaL
drop first. Wheels typically end up lookin super goofy without a drop
Old May 20, 2012 | 08:15 PM
Phresh2010's Avatar
Phresh2010
Stock wheels with drop>wheels without drop
Old May 20, 2012 | 08:21 PM
Alex350's Avatar
Alex350
Originally Posted by SnowPeas
drop it for sure.
+1 get the coilovers first
Old May 20, 2012 | 08:24 PM
kwikshift's Avatar
kwikshift
another vote for coils first, plus it gives you time to hunt down the wheel you want
Old May 20, 2012 | 09:26 PM
ZeroSeVen's Avatar
ZeroSeVen
Go with coilovers first
In that way you'll be able to visualize and gauge on how much clearance you have left between your tires and fenders.
If you want to go with 20's without doing any extensive fender modifications then your best bet is to get the most conservative offset and you'll be able to get away with slightly stretched tires.
This is an example of a conservative offset. Please note that you will experience rubbing if you decide to lower your car for more than an inch and a half. Most that you would do with this set up is heat gun your fender liners.
20 x 8.5 Front (anything with a 38+ offset) with 225/30 tires
20 x 10 Rear (anything with a 42+ offset) with 255/30 tires
Masciaman's Avatar
Masciaman
okay cool thanks for the help lol yeah i was debating about the wheels first just to get the higher priced **** out the way but yeah def going with the coils first
Old May 20, 2012 | 10:18 PM
rookieIS's Avatar
rookieIS
Coilovers first no brainer
Old May 21, 2012 | 11:51 AM
CircuitMS's Avatar
CircuitMS
Coilovers are a good choice, as then you'll be dropped and will have suitabilities for getting wheels later.
If you want some help finding a good kit for your needs and budget shoot us a PM
Old May 21, 2012 | 11:53 AM
Quik208's Avatar
Quik208
Coilovers. Thats an easy choice.
Old May 21, 2012 | 12:02 PM
Hoovey689's Avatar
Hoovey689
2UR-GSE Owner
SWAY BARS! then coilovers
Old May 21, 2012 | 12:05 PM
jadu's Avatar
jadu
live.love.laugh.lexus
purchase the wheels, coils, then tires.
