DIY: 2011+ MY LED Headlight Installation ("How To")
#256
Relay flasher
Can you tell me how did you know the relay to use? I’m thing of changing my headlights on my 2008 Lexus is350. I assume since you changed the headlights your using a relay that’s not normally meant for your car. So how did you know the right relay that’s not typical for your car.
#257
#258
Headlights.
I received new headlights, however it has 2 connectors . My original headlights has only 1 connector. Did your new headlights have more connections than the original?
#259
Disregard the msg below. I found that the connector had to be disconnected from my auto leveling function motors
QUOTE=Jaiken;10159856]
[/QUOTE]
#260
Gasket?
So I purchased the 12' headlights and new ballasts from theretrofitsource. There looks like a groove in the headlight's housing, between the housing and ballasts for a gasket. can anyone verify? Thx!
#261
#263
yes, unless you want to buy OEM 2011+. The guide on this thread shows you how to cut 2006-2010.
kenny5588
11-10-15 05:16 PM
yammy
14
03-18-14 03:21 PM
Tactical
06-25-13 05:15 AM
