drifting.... then boom. alignment problem
Old Mar 21, 2012 | 08:57 PM
rayac88's Avatar
rayac88
Default drifting.... then boom. alignment problem
decided to drift a bit and hit a tree stump just off the side of the road my driver rear toe is pointed in. help me identify what part it is that is damaged i dont think it is the control arm for the toe but i bent the hub that holds the rotor and the axle. i need to know what part it is so i can replace it.
edit: did some more research it is the housing where the axle goes through and all of the control arms connect to behind the rotor. on sewell shows $400 for the part but that cannot be possible. where could i find that part from?
you can see the metal is bent. but when i looked at the mount it seemed fine.
this is the control arm that it is. it connects to the bottom of the chassis.
Old Mar 21, 2012 | 10:46 PM
evogt500's Avatar
evogt500
You ruined the carrier sub assembly. Yes it cost around $400 to $500 for a replacement and more for labor. I guess you got to pay for your mistakes. Good luck.
Old Mar 22, 2012 | 01:14 AM
smokyis350's Avatar
smokyis350
lol ...................
Old Mar 22, 2012 | 01:38 AM
KillaIS250's Avatar
KillaIS250
LOL no offense but ....you made a thread about your fail?
Old Mar 22, 2012 | 01:44 AM
crazybuggy's Avatar
crazybuggy
dont mean to be rude but i like yur thread title. it made me "lool" lool
Old Mar 22, 2012 | 02:12 PM
rayac88's Avatar
rayac88
I don't take it personally.... I was laughing when it happened but hey s*** happens... But does anyone know of a place I can get a used carrier assembly?
Old Mar 22, 2012 | 02:27 PM
ISX50URRA's Avatar
ISX50URRA
DM me. I could point you in the right direction..
Old Mar 22, 2012 | 03:21 PM
ibidu1's Avatar
ibidu1
Use car-part.com and buy the part used. No need to pay 400 im sure you can find it for 60-100 bucks
Old Mar 22, 2012 | 03:59 PM
ibidu1's Avatar
ibidu1
Check this out i found on ebay
http://www.ebay.com/itm/LEXUS-IS350-...921639&vxp=mtr
Old Mar 22, 2012 | 04:21 PM
Sango's Avatar
Sango
Was this at a track?
Old Mar 22, 2012 | 04:22 PM
evogt500's Avatar
evogt500
Originally Posted by ibidu1
I believe he needs this (red arrow). Its around $400.
Old Mar 22, 2012 | 04:37 PM
jaytido24's Avatar
jaytido24
drift the opposite way and hopefully it will auto-correct itself. Seen it done in F&F plus i've been to Tokyo like 4 times. but in all seriousness how does this beast handle..seems like its too heavy to whip its big butt around.
Old Mar 22, 2012 | 04:45 PM
Rikg35's Avatar
Rikg35
Drift again but this time record it! Come back harder
Old Mar 22, 2012 | 04:51 PM
mjh09e's Avatar
mjh09e
I have a 350 and ride with the traction off from time to time. It does Well.
Old Mar 22, 2012 | 05:24 PM
rayac88's Avatar
rayac88
yea bald tires.... my new tires just came in today but i wont be putting them on until i get the issue fixed. im probably going to a salvage place and see if i could get it used for like 100.... hopefully. the tires didnt even grip for a split second, the amount of tread left was misleading.
