offset conversion??
Old Mar 19, 2012 | 01:04 PM
Dexterr's Avatar
Dexterr
Default offset conversion??
Can ISx50 be converted to 5x120 lug pattern? If yes, is ET27 (bmw offset) same offset for ISx50?
Saw nice set of wheels, thinking of buying - as second set. However, only available for BMW.
BMW fitment
•Offset: ET 27
•Center bore: hub-centric 72.6mm
5x120
Old Mar 19, 2012 | 01:30 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Not going to happen I don't think. That offset is already pretty low for an IS, and if you had a conversion spacer in there, you'd probably bring it down to at least a +12 offset, way too low for an IS.
Jeff
Old Mar 19, 2012 | 01:51 PM
Dexterr's Avatar
Dexterr
That's what I thought as well Jeff. Thanks man!!
I had a feeling there was an adapter for the lug pattern. My concern was the BMW to Lexus offset conversion. From what you described, definitely not going to fit and/or not worth trying.
Anyway, pic of the wheels (below). 18x10 (f), and 18x10.5(r). I wanted to go with beefy tires ( (track look) with my next wheel setup, looks like its not going to happen with these wheels. Time to buy an e90 M3.
Old Mar 19, 2012 | 03:20 PM
is150's Avatar
is150
Ill try to find the thread. But i am almost certain a member had a set of 5x120 wheels re drilled for our bolt pattern. Probably more trouble than its worth though
peteharvey
Nov 22, 2015 12:15 PM
xx69xx
Jul 19, 2007 05:27 AM
Chigga
Wheels, Tires & Brakes Forum
Sep 17, 2005 04:31 PM
Blackmarket
Apr 5, 2004 05:46 PM
CmputerWiz
Jun 29, 2001 12:44 PM
