what ipod integration is this??
Old Mar 9, 2012 | 01:32 PM
grassmoker's Avatar
grassmoker
Default what ipod integration is this??
Saw this on youtube and caught my attention
I have 2006 is350 non ML btw..
Old Mar 10, 2012 | 06:49 AM
xMrfreezex's Avatar
xMrfreezex
People are saying he used this cable connection ....
http://www.cellphoneshop.net/av30.html
Old Mar 10, 2012 | 08:56 AM
grassmoker's Avatar
grassmoker
Thanks bro il try it out since its only 20bucks lol
Old Mar 10, 2012 | 11:09 AM
Asakura58's Avatar
Asakura58
where did he plug that Composite Audio and Video Cable into? the stock screen :S
Old Mar 13, 2012 | 10:07 AM
cdubb883's Avatar
cdubb883
How did he get it to work on the screen without composite hook ups in the rear of the radio? plus it dont have usb behind it unless he has a 08, 09 IS with usb.
Old Mar 13, 2012 | 11:01 AM
ydnandy's Avatar
ydnandy
huh? Do 08 have USB? if so, where?! I need to go look at mine
Old Mar 13, 2012 | 11:04 AM
Kurtz's Avatar
Kurtz
USB wasn't standard until 2010.
Some older models could get a lexus-resold ipod kit installed by the dealership though, but it locked you out of using XM radio
Old Mar 13, 2012 | 11:34 AM
xMrfreezex's Avatar
xMrfreezex
Not sure, I just found the info on his blog and youtube channel.
Old Mar 13, 2012 | 12:12 PM
Herofmine's Avatar
Herofmine
He hack the wires from behind the unit, you need wiring diagram for headunit and find input video wire.
Also u need one resistor and control switch, to change between headunit ac/radio/nav/ from ipod integration.
Maybe i will do it when summer comes, but u will not able to control your ipod from headunit only volume will be working
... Anything else you should do it thru your ipod/iphone.
Old Mar 13, 2012 | 08:13 PM
robertrios's Avatar
robertrios
just get a media linq + and call it a day you still get touch screen and the steering wheel controls
Old Mar 14, 2012 | 07:44 AM
ahmed24's Avatar
ahmed24
Sorry, I'm not on here as frequently as before so unable to answer questions as fast. That video is mine basically the way my mod works is simple. I now have an iPhone 4S and this system is still working for me.
The setup involves installing an AV unit for the Lexus IS250 which provides me with the facility to add DVB and 2 additional RCA auxillary inputs. It also allowed me to wire-up headrest monitors to the factory DVD system. Once this was complete, I made a simple iPhone/iPod dock that was hard-wired directly to one of the RCA input sources. You can find more information on how I built the dock on the following thread
And finally, to actually enable mirroring I JailBroke my phone and installed a free software called TVOut2. It's an amazing piece of software and the latest version is very good.
Hope that helps.
Old Mar 14, 2012 | 11:49 AM
Herofmine's Avatar
Herofmine
Unhappy
Hope that helps.
Ahmed, i understand that you used Double DVB Tuner but where did you connect video? Which wire did you use behind unit?
Old Mar 14, 2012 | 11:52 AM
grassmoker's Avatar
grassmoker
Hope that helps.
thanks alot ahmed that really helps alot! you the man bro!!!
BLu_Gs3
Sep 1, 2010 05:02 PM
my808lexus
Apr 24, 2010 05:48 AM
AccElan01
Aug 10, 2007 06:24 AM
Zodiacal
Hybrid Technology
Dec 16, 2006 03:36 AM
jcboiz
Jul 20, 2006 12:59 PM
