Check Engine Light
Old Feb 1, 2012 | 01:00 PM
nitrotang's Avatar
nitrotang
Originally Posted by calvin2376
Can you elaborate more on when you saw the CEL? Were you able to drive the car after the accident? Was it showing up then? There are three periods of interest:
1) Before the accident
2) After the accident, before the repair
3) After the repair
It's clear from this thread that you saw the CEL after the repair, meaning after the body shop had it. Were you able to drive the car prior to the body shop having it but after the accident? Or was it not driveable?
I don't think you'll have any luck with warranty coverage as they'll claim it was related to the accident or the repairs from the accident, unless it ends up being something totally removed and separate from where they repaired but that's a stretch. I think you'll have more luck with the body shop, if you can show you didn't have the issue between the accident and their repairs. If that's not the case, then the fix might be out of pocket.
Also, don't just take the body shop's word for it that it's "cylinder misfire". Not that I distrust them, but there should be more info available. Go to Autozone or get yourself your own OBDII scanner. Get the exact code and the exact text of it, and there's more often than not more than one code.
I don't think it's related to the accident in any way since it was just a fender bender and the bumper had a small crack in it. The body shop told me that they took pictures before working on it and there were no Check Engine lights on. I dropped it off last Wednesday and just picked it up last night. When they drove the car out back to me, they either didn't notice the light on or it wasn't on until I did a roundabout check and got in my car to drive home. So technically, the body shop should be responsible for the Check Engine light since it wasn't there before, which they even admit. They told me to call them if the light ever comes on again and they'll cover the expenses for whatever is necessary to get it fixed.
Old Feb 1, 2012 | 01:40 PM
nitrotang's Avatar
nitrotang
Here are the codes that the shop sent me:
1. P0301=CYLINDER #1
2. P0304=CYLINDER #4
3. P0305=CYLINDER #5
Old Feb 1, 2012 | 02:08 PM
laobo979's Avatar
laobo979
If your lucky could just be the spark plugs if you never changed them. Then again maybe the coil pack?
Old Feb 1, 2012 | 02:20 PM
nitrotang's Avatar
nitrotang
Just changed the spark plugs 2 months ago. What's the coil pack?
Old Feb 1, 2012 | 03:38 PM
calvin2376's Avatar
calvin2376
The symptoms you described above sounded a lot like the carbon build-up issue, can anyone confirm if these are codes that are thrown when the carbon build-up issue arises?
Old Feb 1, 2012 | 03:51 PM
Pnthrzrule's Avatar
Pnthrzrule
I can confirm that carbon buildup does NOT throw codes. Your car just shudders at stoplights at random moments in time...no rhyme...no reason...no codes.
Old Feb 1, 2012 | 04:24 PM
PlacidBoi's Avatar
PlacidBoi
Do not fully trust the dealership as well.
I took my car to Keyes Lexus for inspection, because after the car accident, my car was fixed at a shop that was recommended by my insurance company.
After the fix, my Cruise Control works like 2/10 times. The other times, my light would go off, and it would say "Check Cruise System"
I took it to Lexus, and they claimed that it was a really big deal and if i wanted to get it fixed, they would charge me 950$ including labor. Keep in mind that I have warranty but it doesn't cover since it was related to an accident.
I took it home and my gf's dad owns a shop, so I asked her dad to look up on it. When he looked at it, all it was, was a lose connection between the cables. It was as easy as plugging them back together tightly with some tape and bam! it's done...
scarylar
Build Threads
Jul 26, 2014 01:17 PM
lexusity
15
Jul 5, 2013 01:26 PM
Squirrl
Performance
May 18, 2010 03:13 PM
cricha9
Feb 18, 2009 11:57 AM
zacky
Nov 7, 2008 12:09 PM
