Problem with starting my IS, help!
Old Jan 7, 2012 | 08:05 AM
Lexasaurus's Avatar
Lexasaurus
Unhappy Problem with starting my IS, help!
Hello CL friends, haven't posted in a while - hope everyones doing great and a happy new year to all!
Having an issue starting my IS this morning, a bit confused. (video link below)
http://youtu.be/r0bCsvEPYho
Any suggestions? Battery connections looked fine.
Old Jan 7, 2012 | 08:23 AM
MIA_LEX's Avatar
MIA_LEX
Wow.. never seen that. unplug the negative terminal on your battery and reset your ecu and try it again..
Old Jan 7, 2012 | 09:32 AM
iKenn's Avatar
iKenn
Just call me "Sprinkes"
Thats a loud exhaust.
Are you giving it gas or is it revving on its own?
Old Jan 7, 2012 | 09:41 AM
carlos3366's Avatar
carlos3366
loose/dirty temp sensor, the dreaded carbon build up? reset ecu first it may calibrate itself.
Old Jan 7, 2012 | 10:03 AM
Denver's Avatar
Denver
i would discount the battery first and let it sit for like 10 mins. check your connection with the map sensor and check all vacuum hoses, clamps, and air filter housing. if everything is ok, then its probably the idle control valve
Old Jan 7, 2012 | 10:23 AM
moses0324's Avatar
moses0324
95% sure it's your iac (idle air control)..if it runs when above idle that is likely the culprit. This exact problem occurred on our boat which has 2 v8 6.2l engines
Old Jan 7, 2012 | 11:46 AM
LEXtegra's Avatar
LEXtegra
I'm with these guys. Classic symptoms or a vacuum leak. Like stated above check all your air hose and clamps. Make sure you do a thorough check. Good luck.
Old Jan 7, 2012 | 11:51 AM
ximd's Avatar
ximd
I agree with lextera. i've seen this happen with some other cars and its usually a leak somewhere.
Old Jan 7, 2012 | 12:01 PM
Lexasaurus's Avatar
Lexasaurus
Thank you for the responses!
Going to try this when i get home, i only checked for build up on the battery, had to run errands.
It roars on start up for a few seconds, invidia mid pipe and greddy exhaust.
Doing it on it's own, i was thinking about giving it a little gas but too afraid.
I would hate if this was carbon build up, what are some symptoms that i could have seen that could lead up to carbon build up? i just got an oil change about 800 miles ago, it ran fine but it did idle a bit high in cold weather, or until it warmed up.
Plan on doing this when i get back home. Idle control valve hmm.
I usually don't drive it in the winter because Cleveland winters are terrible but we haven't had much snow at all so i have been driving it till they start pouring salt on the roads. Sometimes at red lights the rpms will jump up to 900-1100 and it feels like it wants to go, i have press the brake a little harder - this seems to happen mostly upon warm up, first 5 minutes of driving.
I'm assuming Idle control valve and IAC are the same thing?
Old Mar 14, 2012 | 11:42 AM
Lexasaurus's Avatar
Lexasaurus
Wanted to follow up, last weekend i checked for leaks (all fine) and disconnected battery for 15 minutes - it's still doing the same thing.
Ordered a flatbed to come and pick up the car tomorrow morning to bring to the shop, will follow up this weekend as to what the culprit was, hopefully nothing major!
Old Mar 14, 2012 | 01:36 PM
vers617's Avatar
vers617
This exact same thing happened to me last week tried turning it on a few times the last time i just pushed down hard on the brake and it finally turned on havent had the issue since. Curious to know what the dealer will tell you
PericoSC
Aug 26, 2023 12:53 PM
lexag12
Dec 6, 2015 07:33 AM
criminalR1
Apr 22, 2011 03:03 PM
wooziewest
Mar 19, 2009 07:56 PM
maydneb
RX - 1st Gen (1999-2003)
Sep 24, 2008 07:26 PM
