Traction???
Old Dec 20, 2011 | 04:37 PM
nonopr01's Avatar
nonopr01
Default Traction???
Does the IS has traction in both back wheels???
I cant find any information.
Thanks.
Old Dec 20, 2011 | 05:42 PM
albis350's Avatar
albis350
We have electronic lsd if I am not mistaking no mechanical LSD on 250 or 350, only the IS-F has mechanical LSD and the newer models not sure if was 2011 when they started ...car still hooks off the line if driven correctly
Old Dec 20, 2011 | 06:53 PM
Gville350's Avatar
Gville350
We all have a stock "open differential"...read up :
http://auto.howstuffworks.com/differential2.htm
Old Dec 20, 2011 | 09:24 PM
SiskoMax77's Avatar
SiskoMax77
Open diff is what we have, I am buying an OS Giken in February. It's an amazing diff for our cars
Old Dec 21, 2011 | 04:14 AM
nonopr01's Avatar
nonopr01
Thanks you. Is the a limited slip differential that we can buy for the IS??
Old Dec 21, 2011 | 08:45 AM
Sango's Avatar
Sango
Yes it is but then if you're planning on using the same pumpkin it's going to cost more than buying a new pumpkin because of the labor involved of taking the pumpkin off and opening it to swap it out and put it back in.
Another alternative which can be cheaper is to buy the IS 300 pumpkin, then all one needs to do is to get the new carrier (ie. OS Giken), and swap it in with the stock. It simplies things because all the tech needs to do is to swap pumpkins now.
Old Dec 21, 2011 | 09:42 AM
Kurtz's Avatar
Kurtz
Note that only works for the IS250.
the 350 uses a different size. Your only options there would be one of the stupidly expensive aftermarket diffs, or possibly an IS-F one (which is also gonna be stupidly expensive unless you find one in a junkyard or something)
Frosted123
Dec 5, 2024 11:52 PM
Ke0
IS - 1st Gen (2001-2005)
Jan 16, 2012 09:56 PM
SC400DRFT
Sep 16, 2006 06:05 AM
sourcemine
Feb 4, 2005 12:25 PM
Cannonbear
Performance
19
Jan 24, 2005 03:44 AM
