HID Install, immediate check engine light
Old Dec 15, 2011 | 08:40 AM
ThermonMer's Avatar
ThermonMer
Default HID Install, immediate check engine light
What gives? I also have that warning light for what i think is the traction control? the orange light with an image of the car on swerving pavement. i toggled through the traction control settings, but it didnt change/fix anything.
DDM 35W 5000k for the stock halogens - i did not buy / install the relays, and i did not disconnect the battery during the install. the car was turned off during the install, obviously. one of the ballast buzzed the first time i turned it on, but that is no longer the case. no flickering either. i also checked the o2 sensor plug for the intake.
Old Dec 15, 2011 | 08:58 AM
Bichon's Avatar
Bichon
Ignore the "Check VSC" and traction control symbol for now -- for some reason, the ECU disables stability and traction control whenever the check engine light is on.
Did you turn on the ignition when some of the cables were still disconnected (to see whether the lights were working before buttoning everything back up?)
Buy or borrow an OBD II code reader, or go to Autozone to get the codes read for free. It's much easier to diagnose when you aren't guessing.
Old Dec 15, 2011 | 09:04 AM
LexStylez's Avatar
LexStylez
I had the same warning light. Try disconnecting the battery and then reconnecting it.
Old Dec 15, 2011 | 09:20 AM
ThermonMer's Avatar
ThermonMer
Yes and yes...i must have turned on the car when the o2 sensor was disconnected to check to see if the lights were working.
should i disconnect both positive and negative on the battery? and do i need to reset my windows or other parts?
thanks!
Old Dec 15, 2011 | 09:28 AM
LexStylez's Avatar
LexStylez
I only disconnected the negative battery. Once I reconnected the battery, the warning lights were gone. I hope everything works out.
Old Dec 15, 2011 | 10:35 AM
Jzsicklexi's Avatar
Jzsicklexi
Yeah just reset the battery and you're good to go.
Old Dec 15, 2011 | 10:54 AM
calvin2376's Avatar
calvin2376
Grab an OBDII scanner so you can check and clear codes without disconnecting the battery. Also, check the MAF sensor - I forgot to reconnect it after my install.
Old Dec 15, 2011 | 12:30 PM
Gville350's Avatar
Gville350
For future reference, it is best to always disconnect a terminal from off the battery when doing anything electrical to your car. GL on the fix...should be as simple as a battery reset.
Old Dec 16, 2011 | 06:19 AM
ThermonMer's Avatar
ThermonMer
thanks for the help....the problem actually fixed itself when i went back to the car.
TroyzLegit
Aug 18, 2018 03:07 PM
Janet23
Jun 13, 2018 05:43 PM
Farino81
Jul 5, 2009 02:06 AM
willy431@aol
Maintenance
Mar 7, 2004 06:51 PM
