Need some info help!! (Car just died)
Ok so the toy trucks on the way
my IS350 just died went to start it and nothing no light nothing hooked up a booster nothing cables nothing. No cranking nothing at all just dead. Has this happend to anybody else???
Batteries can die very suddenly. If it has a bad cell, it can effectively "open" internally and you will not be able to jump the car or have any power until you change it. Most factory batteries are expected to have a 3-5 year life in a properly working charging system... some can go longer, some are just crap and die sooner. With the cooler weather we will see more batteries giving up.
When your car is not running you draw current for start and accessories from the battery, after it has started you draw current from your alternator. Your Alternator went bad... then drained your battery.... classic ... Hopefully you can recharge your battery... or thats another 100 bucks to fix the problem.
I heard the alternator is easy to access, but runs around 400 dollars...... post several days ago stated dealer wanted 1,000 bucks to change the alternator so try and do it yourself, take pictures and help the other CL members out!
Good Luck and keep us posted.
Lexus813
Apr 20, 2012 01:28 PM
