Ride Quality
Old Oct 16, 2011 | 02:35 PM
jadeboy's Avatar
jadeboy
Default Ride Quality
My 2007 IS 350 is approaching 38000 miles; I am starting to feel the car is losing its Lexus quality firm, smooth, and solid ride (maybe because I’ve taken it to the track), the car seems to be more loose in driving and I can feel more of the road. What should I replace to bring it back to the Lexus ride?
Old Oct 16, 2011 | 02:38 PM
nmpeter's Avatar
nmpeter
Is your alignment in spec and are your tires good?
Old Oct 16, 2011 | 02:48 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Provided everything is in spec, etc. I'd suggest the biggest improvement you could do to bring it back to the way it was would be to replace the shocks. They're probably the first thing to wear out, even if they aren't showing signs of leakage.
Jeff
Old Oct 16, 2011 | 02:49 PM
jadeboy's Avatar
jadeboy
Tires are good, alignment is a little out.. drifting a little to the right.
Old Oct 16, 2011 | 02:55 PM
MyIS350G's Avatar
MyIS350G
alignment, balance, better tires, new suspension
Old Oct 16, 2011 | 03:11 PM
vanhouang's Avatar
vanhouang
does anyone know why my rear tire has a rumbling sound? could it be the bushing before the bearing?
Old Oct 16, 2011 | 05:30 PM
Toymota's Avatar
Toymota
Checked your tire pressures? Even a 2 psi change, I can feel a difference in ride. Since it's getting cooler it decreases about 1 psi for every 10F/5C decrease in temperature, and it increases about 3 psi after driving, so compensate accordingly.
Old Oct 16, 2011 | 05:42 PM
Sango's Avatar
Sango
vanhousang, do you mean pulsation? Could be bearing or wheel hub assembly.
Davidsofia
Oct 8, 2018 04:40 PM
hmkim
Jul 11, 2015 09:28 AM
Jbthompson
Jul 14, 2011 07:12 AM
NoS
Jan 18, 2005 02:02 AM
bluelex
Suspension and Brakes
13
Aug 21, 2003 08:59 AM
