I dont know if this is the problem but, I put spacers (20mm front and 25mm back) on my stock IS 250 to widen the stande and looks and after 3-4 days driving it, the check engine light came on and the tracktion control light also came on????????
Has anyone had these things happen??
I have appointment tomorrow with service at the Lexus dealer hopefully the spacers are not to be blame for this and it is just ruting check up of the 30,000 miles it has.
^^^ what he said< yeah i would go back and check all the conections around where you had to work when installing the spacers just in case something got loose or forgoten, suerte panita!
oh yeah absolutely, did not knew you have warranty. hopefully they wont notice the spacers or if they do wont blame them. G luck. hope everything goes smooth for you.
When I lifted my Tacoma, the ABS light came on because I stretched the cable and broke a wire inside. But, the service engine light never came on. I think it's probably just a coincidence. I've had my spacers on for a week and put about 800 miles on the car without any issues.
Lexus already called me to pick up the car. No issues found just a check engine light malfuntion when car was cold. No codes were found. $47.00 for an oil and filter change and gone.
i was goin to ask if u had an intake, sometimes a loose connection will throw codes 01710 i believe meaning running rich bank 1 and bank 2 (seperate code)
