Timing Chain Question
Old Sep 9, 2011 | 10:55 PM
RobzKar's Avatar
RobzKar
Default Timing Chain Question
Ok so does this have to be changed out? I'm changing my water pump and thermostat, and was wondering about the timing chain. Gear heads please chime in. Thank you guys.
Old Sep 9, 2011 | 11:18 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Not unless there are issues with them (there are 3 chains).
If you've got strange sounds, or your engine was starved of oil, I'd maybe check into changing them, but under normal circumstances, there is no need, and it is an involved (to say the least) process to change them. Not really a typical DIY job, at all.
Jeff
Old Sep 10, 2011 | 07:56 AM
Gville350's Avatar
Gville350
I posted in your other thread, so I know what you'll soon be going.
You'll not be needing to do anything with the chains really...unless like Jeff said, if you're having issues with noise. Of which you're not; so save your change.
gebo
Sep 6, 2015 10:38 PM
Kelfin
Performance
Jun 3, 2012 09:07 PM
shetown
RX - 1st Gen (1999-2003)
Nov 5, 2010 12:27 AM
Sup2jzgte
Oct 3, 2008 07:07 PM
Pogo
Dec 19, 2006 07:57 PM
