is250 clock
Old Aug 14, 2011 | 02:13 PM
earthman's Avatar
earthman
Default is250 clock
Just curious, has anyone figured out a way to modify the clock on the is250? To me it looks like the same clock found in the 1990 camry...
The honda guys used to put a piece of film in front of the numbers to give it that "JDM" amber look. I thought it might be possible in this case as well.
Old Aug 14, 2011 | 02:17 PM
evogt500's Avatar
evogt500
Early model 2IS's have the white colored numbers and late model 2IS's have the green ones. Maybe swapping in a older models version will work. There was a thread don here about that so do a search. Hope it helps.
Old Aug 14, 2011 | 02:54 PM
kinglexus99's Avatar
kinglexus99
I think the green clock looks fugly...especially since it was originally the led looking white and then lexus got cheap cuz of the economy and replaced them with the nasty green ones.
Guess its all realitive and Lexus only seems to be getting cheaper...IE removing AFS, key in trunk sensor, etc.
Pretty soon the 250 will come with hub caps instead of actual rims! =X
Old Aug 14, 2011 | 03:06 PM
chi123's Avatar
chi123
It can be changed. When I was changing all my dash lights to white/blue, it's just LEDs underneath the clock panel. If you have the green clock, film over it isn't going to work but if you have the white clock, then films will work.
Old Aug 14, 2011 | 06:50 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
The only difference between the early clock (06-08) and later clock (09-11) is the lens over top of it. Lexus changed it from red to black (hence changing the colour of the clock) for 2009. I ordered the red clock lens from the 2007-2008 model for my 2011 and it fits right on. While the white clock doesn't match exactly, it looks quite a bit better than the off-green colour that it had to start with.
So much nicer, and the new clock lens only costs about $5.00-10.00, not bad at all.
My 2011:
For reference if anyone wants to go either way:
81950-53110 - 07-08 White Display (with Nav, has 2 holes in clock lens)
81950-53120 - 07-08 White Display (without Nav, no holes in clock lens)
81950-53230 - 09-11 Green Display (with Nav, has 2 holes in clock lens)
81950-53150 - 09-11 Green Display (without Nav, no holes in clock lens)
Hope that helps in case anyone was considering it.
Jeff
2025 Edit: The clock display isn't quite the same between 06-08 and 09-11, using the earlier lens doesn't quite give the same look as 06-08. That said, 12-13 used a black lens with white display and is by far the best option.
Old Aug 14, 2011 | 06:59 PM
KillaIS250's Avatar
KillaIS250
^ Dang! good looking out
Old Aug 14, 2011 | 07:29 PM
evogt500's Avatar
evogt500
My 2011:
Jeff
Jeff
How did you get your Drivers side Temperature to 200?!
Old Aug 14, 2011 | 07:32 PM
Sango's Avatar
Sango
That's actually 20.0 Celcius, which is 68 Fahrenheit.
Hard to see the "." in there in the picture but it's barely noticable.
Canadian car.
Old Aug 14, 2011 | 08:06 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Canadian car.
Correct. 20.0.
Jeff
Old Aug 14, 2011 | 08:11 PM
evogt500's Avatar
evogt500
Correct. 20.0.
Jeff
Ahh I see. Mine (US version) changes in increments of one degrees, doesnt go into the first decimal. I wonder if all 2011 are like that.
Old Aug 15, 2011 | 12:27 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
They're all the same for all years, you probably have a larger range with F than I do with C. I can go from 18.0 to 32.0 in increments of 0.5. Not sure what the USA ones go from, but probably like 68 to 80 or something? I think you've got more numbers in there, so don't need the halves. In fact I don't really need the halves either, but they're there anyways, haha.
Jeff
Old Aug 15, 2011 | 01:10 AM
Sango's Avatar
Sango
Jeff
For US, it's like this.
Lo, 65-85, Hi. Direct conversion to C is 18.33 to 29.44.
Canada has more range then.
Direct conversion from Canadian.
64.4 to 89.6.
Old Aug 15, 2011 | 01:30 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Even though we apparently have a larger actual range of temperature from low to high, 18 to 32 is only 14 degrees, while 65 to 85 is 20 degrees.
If you look at the same range of temperatures, 18 to 29.5 for the 65-85 the USA cars have, it's 11.5 degrees to 20 degrees, which is why we get the 0.5 degree intervals, to allow for the same amount of control/adjustment that the USA cars get within that range.
Basically every degree you raise in Celsius is similar to raising it 2 degrees in Fahrenheit within this range.
Jeff
Old May 29, 2012 | 06:06 PM
jgarrido's Avatar
jgarrido
Hi Jeff, to change my clock like yours (2011) I have to order the white display 81950-53120.
where I buy it?
thanks ......
Old May 29, 2012 | 07:12 PM
slimjimtel's Avatar
slimjimtel
Sewell
http://is.sewellparts.com/oem-catalo...S350-2006.html
