19" Tire Size?
Old May 8, 2011 | 01:04 PM
Sango's Avatar
Sango
Default 19" Tire Size?
Is Lexus's recommended tire sizing for the rear suppose to be 255/35/19?
Looks like Lexus site may have it wrong since they have it listed as 225/35/19 but it does not seem to look right...
Old May 8, 2011 | 01:15 PM
Acingteam's Avatar
Acingteam
It sounds about right. Once I had 225/40/19 on an 8.5" wide rim, and there was no stretch at all. So, I'm pretty sure the sizes are correct.
Old May 8, 2011 | 01:22 PM
Sango's Avatar
Sango
Well because for 18" staggered, it's 255/40/18 on 8.5". So for 19", 225/35/19 on 9.0, when I put it in a wheel calculator, the speed is thrown off unless I put it as 255/35/19, which is why I think something is a bit odd.
I also looked at tirerack and filtered down the 19" option and it too saids 255 for the rears.
Old May 8, 2011 | 07:28 PM
CalitriSC's Avatar
CalitriSC
It should be 235/40/19 for the front and 255/35/19 for the rear. Thats what came stock on my IS-F which is 19x8 and 19x9.
Old May 8, 2011 | 07:48 PM
Sango's Avatar
Sango
Originally Posted by CalitriSC
It should be 235/40/19 (think you meant 225!) for the front and 255/35/19 for the rear. Thats what came stock on my IS-F which is 19x8 and 19x9.
Come to think of it, I think Lexus also have the IS-F information wrong as well.
http://www.lexus.com/performance/
If you look at the IS-F and highlight the tire that's on there. It saids the car uses a 9.5" wheel for the rear. But looking at the spec info, it saids 9.0 rear.
Old May 9, 2011 | 09:05 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
The IS F has 19x8 and 19x9 with 225/40R19 and 255/35R19 tires (same diameter front and rear).
The RWD ISx50 have smaller diameter front tires than rear, so for 19's they recommend 225/35R19 and 255/35R19.
So yes, the sizes listed in the original post are incorrect.
Jeff
Old May 9, 2011 | 10:52 AM
DOUGLis350's Avatar
DOUGLis350
I have those F-Sport full faced rims. The correct tires size is as follows:
Front: 225/35/19
Rear: 255/35/19
Old May 9, 2011 | 12:22 PM
BLexodus's Avatar
BLexodus
would the 225/40/19's from the ISF fit ok on the front of an IS350 with a 1'' drop?
Old May 9, 2011 | 06:38 PM
SCWB's Avatar
SCWB
I curious that myself...
Old May 12, 2011 | 08:23 AM
BLexodus's Avatar
BLexodus
Anyone done it, or know?
Old May 12, 2011 | 08:51 AM
flowrider's Avatar
flowrider
Veteran: Air Force
It is in fact a misprint for the size, however the load range listed is correct. The load range for a 225/35/19 is in fact (88Y) and for a 255/35/19 it is (96Y)
Lou
Old Feb 22, 2025 | 09:42 AM
JBPP's Avatar
JBPP
9th Gear
Default Alternate Tire Sizing on a 2017 IS350 FSport
Reviving this thread to ask if anyone has experienced using the following tire specs on a 3rd gen IS350 FSport: 235/40/19 on the front and 265/35/19 at the rear.
The car is currently on RSR half-downs with a 235/35/19 on the front and 265/30/19 at the rear.
Appreciate your inputs.
Old Feb 23, 2025 | 07:52 AM
primavera's Avatar
primavera
Ask the question in 3rd Gen
https://www.clublexus.com/forums/is-...4-present-249/:
vinnier6
Apr 3, 2016 09:13 AM
black08isf
Wheels and Tires Classifieds
Oct 13, 2012 10:20 PM
iGOTlexy
Mar 8, 2010 11:19 AM
tarponman
Sep 16, 2009 11:58 PM
MAS
VIP Style
Sep 4, 2008 04:57 PM
