need help, car vibrating
Old Jan 7, 2011 | 03:31 PM
carbon350's Avatar
carbon350
Default need help, car vibrating
so i just installed a strut bar on my 06 IS350 and every time i come to a stop the car vibrates pretty bad and when i am stopped and in drive the whole car vibrates. it does not do it when i am in park. i took off my engine cover because it was touching the strut bar and the car still vibrates. the strut bar is not touching anything in the engine so i have no idea why its doing this..? either.
any ideas?
Old Jan 7, 2011 | 03:58 PM
Myis350RWD's Avatar
Myis350RWD
No offense. That's why I left my is350 stock!
Old Jan 7, 2011 | 04:02 PM
carbon350's Avatar
carbon350
lol well i didn't think this would happen, i might just take it off and buy something else
Old Jan 7, 2011 | 07:56 PM
timgs300's Avatar
timgs300
Did you check to see that all bolts were fixed and properly torqued? This shouldn't really be a problem. If anything, it would stiffen everything up.
Old Jan 7, 2011 | 08:32 PM
carbon350's Avatar
carbon350
yeah the bolts are tight, how high am i supposed to torque them?
Old Jan 7, 2011 | 09:39 PM
lexusis305's Avatar
lexusis305
Are you sure its not just your brakes like if your rotors are out of round . If its all the when driving and it started after the install then check the bolts, but if its only when braking sounds like you may need to replace or cut your rotors
Old Jan 7, 2011 | 09:42 PM
carbon350's Avatar
carbon350
no i know its not the rotors because i drove the car all day and it never happened until i installed it. and even when i am just sitting at a stop sign or red light it vibrates. the bolts are all tight but i didn't use a torque wrench, am i supposed to?
Old Jan 7, 2011 | 09:47 PM
lexusis305's Avatar
lexusis305
Did you remove a plate that from were the bolts go on .because if its not on the gap may be to much ?
Old Jan 7, 2011 | 11:56 PM
carbon350's Avatar
carbon350
no i all i did was took the bolts off put it on and bolted it down. ive sat there and looked at it for a while to see if i could see anything that could cause it but everything looks fine. i have no idea why its vibrating my whole car
Old Jan 8, 2011 | 07:21 PM
timgs300's Avatar
timgs300
Default Torque
I think the torque is not alot on that. Like 20-40 lb/ft. If you got it tight, then I guess it's tight. Sure fire way to see what's going on is take some time to remove. If problem goes away instantly, that must be it.
Old Jan 8, 2011 | 07:27 PM
CarbonDtls's Avatar
CarbonDtls
Yes remove it and see if it goes away. A strut bar can introduce some vibration into the cabin, not much but it can.
Old Jan 8, 2011 | 07:56 PM
carbon350's Avatar
carbon350
alright ill take it off and see,
thanks
tures
Suspension and Brakes
Apr 4, 2024 09:35 PM
akhowja
15
May 27, 2011 05:27 PM
kenny_evo
Mar 27, 2010 09:01 PM
badx33
Jan 11, 2009 06:47 PM
Shinchan
Aug 23, 2001 03:31 PM
