Something to think about before lowering...
Old Jan 4, 2011 | 05:37 PM
sjgIS350's Avatar
sjgIS350
Default Something to think about before lowering...
Put H&R springs on my 06 IS350 a while back...then new tires...At less than 18K miles, the inner tread is gone on both fronts....Got new tires...and had an alignment done..(or at least checked since there was nothing they could do..no charge)...the toe and caster are right on..Camber is about -1.6 degrees on both fronts...spec is +.04 to -1.1 degrees. Since there is no camber adjustment on the ISx50 and no camber kit is made for the fronts, its something I have to live with...
On these tires I think I will have them dismounted/flipped every 5K..
Old Jan 4, 2011 | 05:42 PM
GSteg's Avatar
GSteg
-1.6 degrees is hardly anything to worry about. How do you know your toe is right on? What was your measurements for front and rear toe?
Old Jan 4, 2011 | 05:43 PM
JMcDonald's Avatar
JMcDonald
Yea from what Ive read....our cars have terrible camber. When I took my OEM wheels off, the rears tires were pretty uneven lol.
Old Jan 4, 2011 | 05:58 PM
graphX250's Avatar
graphX250
what tires are you running?
Old Jan 4, 2011 | 06:07 PM
sjgIS350's Avatar
sjgIS350
here are the readings from the alignment..
as you can see toe is within specs. Tires are Goodyear F1 Allseason. Last set btw..noisy as hell!
Old Jan 4, 2011 | 06:18 PM
juice14's Avatar
juice14
Id be lucky if i get 8k out of my tires jeje
Old Jan 4, 2011 | 06:44 PM
Sffd103's Avatar
Sffd103
Fire Slayer
It all depends how low you are and how much you drive your car.
Old Jan 4, 2011 | 06:50 PM
lexusis305's Avatar
lexusis305
The front camber kit for is300 works on the IS250&350 . It replace the upper control arm ball joint.
Old Jan 4, 2011 | 07:26 PM
sjgIS350's Avatar
sjgIS350
Yeah, seen that posted elsewhere..but not willing to take on the liability of putting on a part not designed for my car...sucker breaks...car loses control...kill or mame someone...not good! Rather spend the $$ on tires than on lawyers and settlements...let alone the guilt.
Chances are it will work fine..but on the off chance.....no thanks to that one.
Old Jan 4, 2011 | 07:27 PM
jaxxx's Avatar
jaxxx
H&r sport??
Old Jan 4, 2011 | 07:28 PM
sjgIS350's Avatar
sjgIS350
Originally Posted by jaxxx
H&r sport??
I believe so...1.3 in the front 1.4 in the rear...or visa versa
F-sport is only .75..which I think leaves camber within spec
Old Jan 4, 2011 | 10:32 PM
lexusis305's Avatar
lexusis305
Thats kool bro ,but its the same set up on both cars front and rear camber kits are the same parts
Old Jan 4, 2011 | 11:29 PM
Hoovey689's Avatar
Hoovey689
2UR-GSE Owner
that's not too bad. I only had the stock Turanza's for 9000 miles. Went from oem to F-Sport shocks/springs at 4000.
Old Jan 4, 2011 | 11:56 PM
iialcii's Avatar
iialcii
ya the inner camber is garbage. my rear wears pretty even though. front is wack driver side more than the passenger but w.e price to pay for being low
Old Jan 5, 2011 | 01:29 AM
crazybuggy's Avatar
crazybuggy
i wna get low, no mattaaaa whatt!
