If it ain't broken don't fix it. Does it apply to the Valve Spring Recall?
Old 12-14-10, 02:40 PM
Dj_AmtraX
Dj_AmtraX's Avatar
Looks like you guys are for performing the repair.
Kurtz,
Where did you find the data that it effects only 0.2% of Lexus owners? I may gamble that 0.2%.
My wife has a 2006 Civic and the only recall notice she got was for rear crankshaft seal. I know that is a major job too, but since hers is a 5 speed we will do it when she needs a new clutch. IMO, it is not as major as valve springs.
I don't have much confidence that the dealership will do the job/take care like it's their own car. My car had a window rattle after the first week of ownership. Two weeks in the shop and almost 200 miles on my new car and the rattle was NOT fixed. Had a rock chip on the hood and scratch on the door panel too. In the end, I fixed the rattle myself by adjusting the window frame and door latch. I am NOT a Lexus trained tech and I figured how to fix it. I regret taking it to them so I don't want to have the same experience again.
Old 12-14-10, 03:09 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
you should try another dealer.....
Old 12-14-10, 03:46 PM
Kurtz
Kurtz's Avatar
Kurtz,
As to a rear seal being major, well, it requires removing the engine or transmission usually, that's pretty major in my book (moreso than just doing top-end work) but YMMV
0.2% is from Lexus themselves-
http://www.lexus.com/recall/#hs3RecallSection
Lexus estimates that the likelihood of a customer vehicle experiencing this condition is two-tenths of one percent (0.2 %).
Old 12-14-10, 04:23 PM
JMcDonald
JMcDonald's Avatar
Look man, its up to you if you want it done. But its pretty much a brand new head. GET IT DONE! If they mess it up, they HAVE to give you a new engine, let them do it...You will be fine. If you can't trust your dealer then find a new one or leave your car be and let everything fall into place.
Old 12-14-10, 04:31 PM
t0e
t0e's Avatar
I am with AmTrax-- I really don't trust them! : l
Old 12-15-10, 07:25 AM
juice14
juice14's Avatar
I shipped my car to another country, I guess Im screwed. Does this apply to all 2008 models?
I know they do the recall here, Im just not sure if they will do it to mine.
Old 12-15-10, 07:58 AM
Micaiah
Micaiah's Avatar
Seems like you have your mind set from the get go not to do it although most people are suggesting otherwise. Even with their reasoning, you still are a fighting fish.
So I'm going to be different and tell you not to do it.
But if it were Micaiah, he'd be done a a while ago...because there is no way I'd sacrifice my family's safety should he stall on the freeway.
Old 12-15-10, 09:03 AM
rebs
rebs's Avatar
No, it doesn't apply to all 2008 models. If you have a late model 2008, you may be ok. The best way to find out is to call or login to the lexus owners page.
Old 12-15-10, 09:07 AM
JMcDonald
JMcDonald's Avatar
If he didn't want it done....he wouldn't be asking what everyone thought.
Old 12-15-10, 09:27 AM
rebs
rebs's Avatar
For what it's worth...I would be in the same boat as the OP on this issue (i.e. waffling on whether or not to get this recall done).
There have been more than a few side effects after the recall (simply search this forum or google it). Yes, they should (and probably will) get fixed, but if these issues happen to you...it's more than an inconvenience, and you can't help but wonder what other side-effects will pop up down the road (possibly under warranty...possibly not, and yes it should be covered either way, but proving your case can be tough).
I'm not saying I wouldn't get it done, but I probably would seek advice (or 'interview' the dealership/service department) because it does seem like there's a risk with performing this recall. Considering this issue only has a 0.2% failure rate (which some car manufacturer's won't even issue a recall for), I don't think it hurts to ask lots of questions.
Just my two cents.
Old 12-15-10, 09:46 AM
Initial B
Initial B's Avatar
OP - I just had mine done (2007 with 51k miles), and all seems fine. Didn't have any issues with driveability when I took it in, either. For your situation, I'd prob wait 6-12 months....let your local techs get more experience with doing the work, since you drive your car so little and have such low miles.
It's highly unlikely you'll have any issues until then, so I wouldn't worry about the safety aspect that others are alluding to. Just take it in when you feel like getting some use out of a loaner for a few days
Old 12-15-10, 10:36 AM
juice14
juice14's Avatar
nvm called lexus and mine is included, that sucks.
Old 12-15-10, 11:15 AM
intellis
intellis's Avatar
I am a lil hesitant on the fix too, but I was equally hesitant on fixing the "click engine noise". The "click engine noise" went well. I trust my dealer.
Go get it done.
MWIS350
05-26-15 03:19 PM
mac777bos
ES - 5th Gen (2007-2012)
11-08-14 09:16 AM
jewel
10-25-11 12:39 PM
Tmoriarty
10-10-10 04:36 AM
VQT
SC- 1st Gen (1992-2000)
05-30-02 08:43 AM
Quick Reply: If it ain't broken don't fix it. Does it apply to the Valve Spring Recall?
