3.6mpg help
Old Dec 7, 2010 | 05:37 PM
  #31
Raralith's Avatar
Raralith
Originally Posted by Acingteam
^ I'm sure that's your butt dyno talking. You won't really notice a 20-30whp difference in a car (especially of this weight)... and I'm sure you didn't gain anything close to that with just an intake.
You will notice 20-30whp, and that's a huge gain for the IS 350. I'm probably only getting 10-15whp more from intake and full catback exhaust, and my times on the drag strip definately improved even factoring in the environment. But, 20-30 whp from an intake though, not likely.
Old Dec 7, 2010 | 05:42 PM
  #32
BlkSapPrl7's Avatar
BlkSapPrl7
your 350 has 12 injectors that fires on cold start.
Old Dec 7, 2010 | 05:44 PM
  #33
Acingteam's Avatar
Acingteam
I disagree. Will you see results? Yes (minimal). Will you actually feel it? Unlikely.
When I had my WRX, mind you the car weighs about 700lbs less, I had the car tuned and jumped 25whp on a Mustang Dyno. I couldn't tell the difference in power. I went from 254whp to 279whp... the car felt more responsive, but that was because of a tune.
Either way the intake would not be a "night and day" difference.
Old Dec 7, 2010 | 09:06 PM
  #34
IS350rock's Avatar
IS350rock
On my intake I notice a huge dirence in my acceleration
Old Dec 8, 2010 | 05:45 AM
  #35
Kurtz's Avatar
Kurtz
You really don't.
You imagine one, but it's just your imagination.
If you actually measured your acceleration times you'd see no significant difference.
An intake, by itself, won't provide more than about 5 rwhp.
Which is not noticable at all, let alone a "huge difference"
The electronic snake oil I mention might give you another 5-10 until the ECU tunes it back out... which again won't amount to a "huge difference"
Short ram intakes such as yours can add a huge amount of noise though- and many people confuse that with horsepower.
Old Dec 8, 2010 | 06:02 AM
  #36
heyarms's Avatar
heyarms
Can i go ahead and ask? How old are you, IS350Rock? How much experience with cars do you have?
And really, take the best advice given by the forum and remove your intake to try and resolve your problem. Even the "imaginary huge gains" your intake gives, i doubt is worth 3.6mpg.
Old Dec 8, 2010 | 10:53 AM
  #37
isthrizzy's Avatar
isthrizzy
OP - are you refilling your tank after driving 40-50 miles? B/C that's what would have to happen if you got 3.5 mpg. If that's the case, revert back to your stock intake set up and see if that resolves the problem. If not, then maybe you need to bring it to the dealer (with stock set up in place) and have them evaluate things.
I find it hard to believe you get 3.5 mph and there is no engine warning light, etc. B/C with that crappy of mileage there would certainly have to be something wrong with the car.
Old Dec 8, 2010 | 05:20 PM
  #38
sjgIS350's Avatar
sjgIS350
Default I think we need a math lesson too.
I really don't understand the gibberish in the original post.
It sound to me that the car has a non-stock intake and the displayed mpg (current and or tank) is fluctuating greatly.
So...lets find out what your actual MPG is.
1) fill tank
2) reset one of the trip odometers
3) drive the car normally until you are just about empty
4) fill tank again.
5) take note of how many gallons it takes
6)Check the miles on the trip odometer you reset in step 2)
7)Divide (this is the math part) the miles from step by the gallons in step 5. MPG = Miles/gallons
What is the answer? Somewhere around 20?
Old Dec 8, 2010 | 06:10 PM
  #39
juice14's Avatar
juice14
I got more than that at the track, thats crazy... like some have said.. just try driving a whole tank and look at the tank avg. city you should get at least 16 and hwy you should get low to mid 20s considering you dirve pretty agressive
metaleckz
Jun 23, 2014 02:47 PM
Shervin021
Feb 10, 2012 09:28 PM
718murdoc
Apr 18, 2011 11:02 PM
SocalSo350
May 20, 2008 02:33 PM
wjimmy
May 20, 2007 09:57 AM
