70K Servicing Due
Old Nov 30, 2010 | 10:01 PM
amuds's Avatar
amuds
Default 70K Servicing Due
Hi All,
My 07 IS350 has 68K. Any specifics i need to check for?
Old Nov 30, 2010 | 10:31 PM
Phresh2010's Avatar
Phresh2010
its all in the owners manuel
Old Dec 1, 2010 | 05:12 AM
Kurtz's Avatar
Kurtz
Originally Posted by amuds
Hi All,
70k is an oil change. That's it.
0-100k they're all just oil changes (and tire rotations if you're an AWD 250) except for 30 and 90k (brake fluid change and air/cabin filters you can do yourself in 5 minutes), 60k (same as 30k plus spark plugs), and 100k (coolant)... plus checking the air/cabin filters every 15k, which you can also do yourself in about 5 minutes.
Old Dec 19, 2010 | 04:23 PM
Shahryar's Avatar
Shahryar
^ You guide on my.is is something I'm trying to follow:
From http://my.is/forums/f126/dealer-vs-m...7/#post5733603
Originally Posted by Knightshade
The 2IS is really pretty easy... by the book you're looking at:
every 5k:
Oil change
(you can go much longer, safely... at least 7500 on normal oil, and at least 10-15k on any decent synthetic, 25k on Amsoil... but 5k is what the book says, the better to make the dealer money)
Every 15k:
Change air filter and cabin filter (you can do these yourself, maybe 5 minutes each, and pretty cheap)
Every 30k:
Change brake fluid- probably gonna pay someone to do this unless you're pretty comfortable working on your car... it's not super hard if you are, but it's one of those things you want to be SURE is done correctly- leaving air in brake lines is a Very Bad Thing.
Every 60k:
Spark plugs (again, can do yourself or not, depending how comfy you are working on cars... this is at least less of a "do it wrong can kill you" thing than brakes :P)
Every 100k:
Engine coolant
Oh, you'll need to change the battery in your smartkey every 2 years or so, if you want to count that.
That's about it for the RWD auto 250 and 350...
If you have an AWD 250 you'll have differential fluid changes in there occasionally... and if you have a manual RWD 250 you're the lucky one who can change transmission fluid (but will also get to change your clutch and flywheel for around $3,000 eventually)
phillies
Jul 2, 2010 11:31 PM
Madsci625
Jun 9, 2010 09:27 PM
moo_juice
Feb 25, 2009 04:29 AM
All4sho350
Mar 5, 2008 06:55 AM
IsraelRX
RX - 1st Gen (1999-2003)
17
Sep 4, 2004 05:01 AM
