oil filter for AWD
Hi all, i was reading some old threads on this, apparently the part number is different for AWD and RWD. I've looked on Sewell and Lextuners.com, and both places only sell one kind (the RWD part if i'm not mistaken). Would that work for the AWD? I gather that the filter element is the same, but supposedly the AWD part has an extra plastic piece and an extra o-ring. Are those needed during the oil change process? If so, i might just order from my dealer so i can get the AWD part number instead of online.
Also, is the drain plug gasket something i need?
thanks!
thanks!
it won't work because you DO need that plastic piece it's one time use only,
correct filter is Toyota 04152-YZZA5
and yes get yourself the drain washers, one time use only as well, you can probably get away with not changing it but for 90cents a pop why risk a little leak...
get it cheap from here
http://www.trdparts4u.com/scripts/pr...dProduct=-8483
swaangin
Jan 1, 2019 03:49 PM
Gs3500
Aug 23, 2015 10:31 PM
crombie92
May 14, 2011 04:56 AM
