HID vertical aim problem
Old Aug 17, 2010 | 09:35 PM
jadeboy's Avatar
jadeboy
Default HID vertical aim problem
I installed Garax 6000K to replace my stock HID. The new HID moves up and down as expected when turned on.
But the AIM of the new HID was too high, so I try using the "Headlight Aiming Adjustmet" to low the HID by using the philip screw driver but no matter how much I turned it clock wise/counter clock wise it does not move up or down at all on either the driver or passenger side.
Anyone have suggestion why this is happening?
Old Aug 17, 2010 | 09:44 PM
WERK's Avatar
WERK
Care to explain in detail? Not really understanding what you're talking about.
Are you adjusting the correct mechanism? Hopefully you're adjusting the one with the circular **** with the gears, if you use a 8mm box wrench, its the right part.
Old Aug 17, 2010 | 10:16 PM
jadeboy's Avatar
jadeboy
When you turn on the car.. it does it inital check by moving the HID up and down.
Yes.. that's what I am adjusting..
Old Aug 17, 2010 | 10:18 PM
shiny250's Avatar
shiny250
i found out when adjusting mine, it takes ALOT of turns to get them right if they are misaligned.
Old Aug 17, 2010 | 10:34 PM
jadeboy's Avatar
jadeboy
Well passenger side is a little higher than the driver side (is this by designed?).. but overall it's a little high.
Old Aug 18, 2010 | 01:20 AM
khoab88's Avatar
khoab88
Default re
ya, driver side is a bit lower to avoid blinding incoming vehicle. that make sense?
Old Aug 18, 2010 | 06:34 AM
Kurtz's Avatar
Kurtz
Don't forget there's two screws for each headlight and you're supposed to adjust both when you adjust the light.
Much easier if you want to simply raise the lights a bit is to adjust the rear AFS sensor arm though.
Old Aug 18, 2010 | 12:31 PM
jadeboy's Avatar
jadeboy
The Lexus manual has diagram of 2 wheel devices to adjust each headlight.. but I can only find 1.. and all the Lexus pictures in this forum.. there seems to be only 1.. I am confused by this.. anyone got REAL pictures showing both wheel devices?
Old Aug 18, 2010 | 02:42 PM
integlspwr's Avatar
integlspwr
the other day my headlight aim was perfect, now today i notice going up my parking strcutre that my driver side is aim noticeably higher.
ANyone know how I can fix it?
I have OEM factory HIDs, and not a Plug and play kit.
Old Aug 18, 2010 | 02:58 PM
don's Avatar
don
When AFS aligns the headlights, wouldn't it undo the manual adjustment of turning the screws. I assume you have to turn off the AFS to use your manual adjusted heights.
Old Aug 18, 2010 | 03:03 PM
JoeCombs's Avatar
JoeCombs
mine are a lil messed up too but they aim too low, but i have springs so the front sits lower than the rear, to my understanding just adjust the AFS sensor, search it, there is a great DIY around here somewhere.
Old Aug 19, 2010 | 06:49 AM
Kurtz's Avatar
Kurtz
Nope. AFS adjusts based on height/angle starting with the base, manual, setting... it doesn't undo manual setting changes.
Old Aug 19, 2010 | 09:07 AM
don's Avatar
don
Nice to know. Thanks
Old Aug 19, 2010 | 12:17 PM
brociouz's Avatar
brociouz
Is there any advantage of doing one method over the other? Aside from ease.
Sharkido60
RX - 1st Gen (1999-2003)
Apr 21, 2017 08:33 AM
06Harrier
Aug 19, 2006 01:21 PM
rominl
Lighting
Dec 2, 2004 02:20 PM
tiguy99
Lighting
Oct 15, 2004 01:06 PM
