wheels not holding air
Old Aug 4, 2010 | 02:19 PM
jnguyen87's Avatar
jnguyen87
Default wheels not holding air
Hey guys i have my 19" dpes and for some reason the front driver side wheel keeps losing air. I had some pretty worn out due to camber wear tires and it was losing air. So i checked them to see if there were any nails or leaks due to camber. Didnt see much. So either way i bought new tires. And that wheel is still losing air. Any suggestions?
Old Aug 4, 2010 | 02:21 PM
AYEmike's Avatar
AYEmike
bad tire valve, a dent in the rim, any cracking ocurring on the tires?
Old Aug 4, 2010 | 02:29 PM
jnguyen87's Avatar
jnguyen87
Bad tire valve coincidently with both old tires and when they mounted the new tires? Not sure. Dont see any dent in the rim either. Never hit that bad of a pot hole. And the new tires shouldnt have a crack or anything in them. The old tires had some major camber wear is all..
Old Aug 4, 2010 | 03:10 PM
laobo979's Avatar
laobo979
Fill your tub up take your rim off and rotate it in the tub till you see were the leak is
Old Aug 4, 2010 | 03:21 PM
ULTiMaX99's Avatar
ULTiMaX99
yeah do a dunk test and see exactly where the leak is coming from.
Old Aug 4, 2010 | 03:37 PM
uz07lex's Avatar
uz07lex
+1 thats the best method.
RVCAis250
Feb 15, 2013 08:45 PM
snakehead
Oct 22, 2010 09:12 PM
EN_VY
Suspension and Brakes
19
Apr 21, 2010 10:49 AM
blklexo818
50
Oct 22, 2008 02:54 PM
D2-AUTOSPORT
Wheels, Tires & Brakes Forum
12
Feb 18, 2003 09:26 PM
