Iphone4 and bluetooth :(
Old Aug 6, 2010 | 09:44 AM
vicc101's Avatar
vicc101
Look for these settings in your iPhone. This is what the Droid's bluetooth settins look like. Good luck!
Attached Thumbnails Iphone4 and bluetooth :(-bluetooth_options.jpg
Old Aug 6, 2010 | 05:39 PM
MBTC's Avatar
MBTC
I don't have a picture to share, but I looked at my iPod Touch in hopes of describing it.
All I did was (from Home screen) was Touch the "Settings" icon, then General > Bluetooth > On.
At that point at the bottom on the iPod it says "Now Discoverable".
When I did that, and put my car audio system on BT-A Connect mode, they just sort of detected each other, at some point (I think on the iPod) I was prompted for the PIN, etc. I guess I learned from the car owners manual that the PIN for BT-A was "0000". The car's PIN for phone bluetooth is a different number altogether.
Also, this *has* to be slightly different than the above on an iPhone where you have 2 kinds of BT, iPod only has one, on or off.
Old Aug 21, 2010 | 10:10 PM
threejump's Avatar
threejump
connecting through bluetooth to use for the phone functions is separate from pairing for bluetooth A2DP to listen to music. look for it under the audio settings and not phone settings.
Old Aug 22, 2010 | 11:43 AM
darrelld's Avatar
darrelld
Originally Posted by nitrotang
Can the Bluetooth in my 2006 sync contact information too?
It cant to the iPhone, there is no contact bluetooth transfer option. Not certain how they are doing this with the 2010 models. I could transfer contacts to the 06 IS with my old Windoze phone.
Old Aug 22, 2010 | 05:50 PM
DOUGLis350's Avatar
DOUGLis350
Would like to know how to transfer contacts as well, have an 06.
Old Aug 30, 2010 | 11:55 AM
djkeebz's Avatar
djkeebz
i have a 3g and i had a similar problem. you need to connect it twice.
it should work fine. i have a 2010 is250. the cool thing is, is that when i watch movies on my iphone it's like surround sound theater. it's kick ***. dont worry bro you'll be fine. wb if you need a walk thru. good luck
Old Aug 30, 2010 | 09:46 PM
IS250Slvr's Avatar
IS250Slvr
Well i got my iphone4 working properly in my 2010 is250 if anyone has any problems shoot me a PM i will walk you threw it
Old Dec 14, 2012 | 01:18 PM
SamiLex's Avatar
SamiLex
Lightbulb Audio Streaming from Iphone to Lexus
The only thing i'm able to accomplish besides phone calls on a lexus 2006 rx 330 from an iphone IOS 6 is streaming AUDIO NOTES. it's DEFINITELY possible to do but i'm sure will need some type of a hack. once an Iphone is paired with truck, either phone calls or your audio notes can be played back. any suggestions?
Old Dec 14, 2012 | 03:23 PM
dong888's Avatar
dong888
I just did my setup a few days ago. I have 2007 is350 so bluetooth music is not supported. I have to use aux-input. You can buy blackberry music gateway 2 from crackberry site ($50). And my car had the ground loop noise issue so i bought the kengsington ground loop isolator from amazon ($9). And on top of it, my usb ac plug had a problem to produce some other noise so I had purchased another cheaper usb charger (short and mini) to stay in the armrest compartment. Now I can play music via bluetooth and it is smart enough to switch between navi bluetooth and blackberry bluetooth. No more gound loop noise either. There are many threads on this setup.
Old Dec 17, 2012 | 08:17 AM
SamiLex's Avatar
SamiLex
Thumbs up Iphone Streaming on Older Lexus Models Can Be Done!!!
i came across this great post and did it myself over the weekend. the admin redid the post after i pointed a couple of things that he/she missed but they now have screenshots and all of how to do this from A to Z. I was looking for a way to stream from my iphone to my lexus truck and didn't want to go with all those cheap radio transmitters but this worked like a charm!!! check out his tutorial on how to stream iphone content to lexus
gc9538
Apr 26, 2018 06:20 PM
IS250Dude
Mar 27, 2018 08:15 AM
aTeAse
Oct 16, 2013 07:12 PM
jbone29
Jul 3, 2012 12:54 PM
GregsLexus
RX - 3rd Gen (2010-2015)
15
Feb 21, 2012 12:43 PM
