Whats this sound coming from my headlights?
Old 06-15-10, 02:22 AM
KPinCS15
KPinCS15's Avatar
Default Whats this sound coming from my headlights?
I removed my headlight assemblies a couple days ago and opened them up to paint the inside. i was 100% sure i put everything back together correctly. NOW though, im not so sure. I just went outside to look as some bulbs to get leds and heard this high pitched whining noise, very quiet though, coming from my headlights. but only when the low or high beams are on. if its just the parking lights on, no noise. could the motor for the directional lights be jacked up somehow? WHAT DID I DO!!!!???
Old 06-15-10, 02:25 AM
Mv350
Mv350's Avatar
haha i think if its just the ballasts. and now your being over precautious about everything cause you didnt wanna mess anything up. hid/afs makes that noise. now if you dont have factory hid i dunno
Old 06-15-10, 02:30 AM
KPinCS15
KPinCS15's Avatar
literally just crawled into bed and remembered. so here i am... leaping out of bed... i did JUST take out the puddle lights to replace them with leds. and i DID turn the headlights on with the puddle lights removed. is there some sort of buzzer that i dont know about? @ Mv350, all my lights are still factory. as far as HID, no idea. how can i tell the difference between HID and halogen? halogens are have a yellow color to them when lit up right?
Old 06-15-10, 02:38 AM
KPinCS15
KPinCS15's Avatar
one last thing... the sound is constant. it wont stop.
Old 06-15-10, 02:44 AM
Mv350
Mv350's Avatar
as long as the lights are on they will make the noise. if i could hear it in person i could let you know exactly what it was. but it just sounds like the power to the HID's, they all make constant noise.
as to figuring out if you have factory HID
HID/afs-lights buzz , they move when turning, the move up then down when lights turn on. if you remove the factory bulb it will say phillips D4s on it. which is HID.
Old 06-15-10, 10:21 AM
brociouz
Uber 1337 Moderator
brociouz's Avatar
I think it's normal. My HID's make the same sound whenever they are on. Sounds like a high-pitched electronic hum.
Old 06-15-10, 10:24 AM
new.era.13
new.era.13's Avatar
^ +1. it will go away when the bulb is complete lit up.
Old 06-15-10, 12:04 PM
kentaro
kentaro's Avatar
sound of the ballst
Old 06-15-10, 01:37 PM
KPinCS15
KPinCS15's Avatar
THANK GOD! haha, i thought i seriously effed something up. im gonna go turn my headlights on now and see if the sounds goes away after some time... hehe
Old 06-15-10, 01:51 PM
mTalion
mTalion's Avatar
Well when you painted the inside of your headlights, you baked them to open them up right? Maybe when you put them back together a small air hole was created through the glue and is making that whistling noise.
Take your car into your garage and turn off all the lights. Then turn on your car's lights and if your headlights are about the same color as your fogs then you dont have HIDs and that is the problem. If your headlights are a bit whiter and brighter then you most likely have HIDs and thats what causes the buzzing noise. That noise shouldnt be too noticable though. GL
Old 06-15-10, 02:07 PM
Initial_K
Initial_K's Avatar
Sound is normal, I have it on my HID headlight as well.
Old 06-15-10, 02:43 PM
Pearl250
Pearl250's Avatar
its normal. i have it too.
Old 06-15-10, 05:08 PM
KPinCS15
KPinCS15's Avatar
I didnt bake them i used a heat gun. and i did just heat up the existing silicon and squeeze the assembly back together. maybe ive got a hole, maybe not. but in any case, the sounds does dissapate after a few minutes. so im not so worried about it anymore. thanks for the help.
ss729
06-02-16 05:21 AM
crenfro
SC- 1st Gen (1992-2000)
11-01-12 09:11 PM
bdar
ES - 5th Gen (2007-2012)
11-12-10 11:09 PM
iialcii
10-28-07 07:47 PM
Quick Reply: Whats this sound coming from my headlights?
