Wheel spacers and Big brakes?? need help!
Hello all. So I received my BBk for my 06' IS 250. Rotora 6 piston front and 4 piston rear. When we test fitted them , we noticed the wheel (19" PIAA super Roza) was hitting the caliper. We added a 8mm spacer. that worked fine for the caliper problem. When we wanted to put the lug nuts on, the were only able to get two turns out of it? So the questions are 1. Is it o.k. to have a spacer on ALL the time? (Rotora didn't recommend it). 2. Is it just as easy as getting a wheel spacer and longer wheel studs? are new lug nuts required? Or should I wait and see till I get the new studs on. Was going to go with a 10mm for more flushness. any help would be appreciated. thanks!
I'm not a offset/spacer/fitment guru.
but heard project kics spacers are one of the best ones with built in extended studs.
http://www.evasivemotorsports.com/me...s_wheel_spacer
So I ordered Ichiba 10mm spacers version 1 which requires to remove old studs. I like the version 2 which has the studs attached to the spacer itself, but Ichiba only makes those starting at 15mm. I found out about Project Kics after I had ordered.kinda worried about the hubcentric ring. They are optional for the Project Kics, but not sure about the Ichibas. MothIS, im not worried about the spare wheel right now. Well, I'm getting them tommorrow. We'll see....
3rdelement
02-25-06 10:18 AM
