My next move
Old Mar 27, 2010 | 11:27 PM
GiantsFan's Avatar
GiantsFan
^ No IS has a full size spare. You can see in that picture [post 10], the bar is supposed to bend like that...
Old Mar 27, 2010 | 11:29 PM
syzygy's Avatar
syzygy
Now, the sway bars don't/can't improve "handling" in the sense of "I can now negotiate this turn x miles per hour faster than before I had sway bars on" because handling at the limit is mostly a function of your tires, correct?
If you have wider tires, for example, I'd imagine your handling would improve because you now have greater surface area touching the road and therefore a larger centrifugal force is necessary for loss of traction (manifesting itself as a larger speed while negotiating the turn)
Someone who knows what they are talking about chime in, this is all mostly intuition.
Old Mar 27, 2010 | 11:31 PM
syzygy's Avatar
syzygy
See in the description when it says sway bars increase "precision"...that I can buy, that I get. Decreasing body roll will give you a greater sense of precision indeed, but it's not going to increase handling at the limit (i.e. you won't be able to negotiate a turn faster with sway bars on than without) because that is still a function of opposing forces (frictional force from tire touching road and centrifugal force)
Old Mar 27, 2010 | 11:35 PM
cdeeznuts's Avatar
cdeeznuts
okay sweet. I'mma throw this f-sport bar on hopefully tomorrow. WEeeEE
Old Mar 28, 2010 | 09:20 AM
Kurtz's Avatar
Kurtz
Incorrect.
It increases handling because it helps resist the transfer of weight away from the wheel(s)
http://auto.howstuffworks.com/question432.htm
Roll is bad. It tends to put more weight on the outside tires and less weight on the inside tires, reducing traction.
Old Mar 28, 2010 | 09:33 AM
syzygy's Avatar
syzygy
Originally Posted by Kurtz
Incorrect.
Ahh I see, cool. That makes sense.
Old Mar 29, 2010 | 10:25 PM
cdeeznuts's Avatar
cdeeznuts
It's official... I F'd up my rear... sways that is. I'll let you know they perform tomorrow.
Old Mar 30, 2010 | 01:04 AM
uz07lex's Avatar
uz07lex
Do the sway bars first. Handeling and braking then prfomance and cosmetics. Thats just my opinion.
Fjaw
Feb 27, 2013 04:28 PM
BVIS250
Mar 26, 2012 10:13 PM
mong
Oct 23, 2011 08:41 PM
bob4256
Apr 13, 2011 09:15 PM
martyb511
Dec 26, 2010 10:48 PM
