HID headlights and fogs
Hey guys,
Iam i correct by saying if i buy a HID kit for my low beams and also buying a HID for my fogs that they would match?
Also, are the low beams H11's and fogs 9006?
NEWBIE NEW!!
NEWBIE NEW!!
They will match if you get the same temperature i.e. 6000k low and fogs, 8000k low and fogs. It would probably be best to order both of the kits from same company/brands.....sometimes different brands' temperature/color can be a little off. GL.
Yes i know this.....but just wanted to make sure i dont have to do any retro fitting in the fogs........
are the bulb numbers right? H11 and 9006?
Beware that putting a P&P HID kit into the reflector fog light housings will cause a lot of glare. For the best match possible, you should look into a projector retrofit. Check this thread out on my lighting setup: https://www.clublexus.com/forums/is-...fogs-pics.html
insomniac
Apr 5, 2010 12:11 PM
