Will those wheels fit? START HERE.
Old Jul 15, 2010 | 01:32 PM
  #1291
Mv350's Avatar
Mv350
The front will rub like crazy on out cars
Old Jul 15, 2010 | 02:00 PM
  #1292
skochur's Avatar
skochur
figured as much...thanks for the quick responses...
Old Jul 15, 2010 | 02:40 PM
  #1293
Mv350's Avatar
Mv350
no problem
Old Jul 18, 2010 | 05:58 PM
  #1294
rcJten's Avatar
rcJten
So how will 20x10 40, and 20x8.5 40 look on an IS350? Will it rub? Spacers needed? What size tires will be best. I do intend to either roll or shave.
Thanks!
Old Jul 19, 2010 | 11:06 AM
  #1295
06tpis350's Avatar
06tpis350
Hi CL volk owner..i dont know if this right place to ask this question. i just want to appoligies in advance. im looking on getting te37 19 here are the spec
TE37's Titanium Gunmetal
19"X8.5" fitment
5X114.5 lug pattern
+43 offset
my question is would they work? not stagggered. i think the rear would work and im guessing just put some spacer on the front. please somebody help me=) Thank you Cl family
Old Jul 19, 2010 | 02:27 PM
  #1296
Mv350's Avatar
Mv350
Thanks!
that should work, maybe shave rear. im not the best when it comes to 20's.
19"X8.5" fitment
5X114.5 lug pattern
+43 offset
those should work. what type of drop. what size tires do you plan on running. and why not staggered?
Old Jul 19, 2010 | 03:14 PM
  #1297
06tpis350's Avatar
06tpis350
hi mv350=) i so this rims locally for $2000 brand new on craiglist.sad they are not staggered. Im not drop yet. But im planning on getting some BCS coil soon too.What the perfect tires set up for no rubbing issues? I currently running spacers on my stockies 18. 15 mm front and 20 mm rear=) thank mv350=) august
Old Jul 19, 2010 | 03:17 PM
  #1298
Mv350's Avatar
Mv350
225/30 front.245/35 rear or 255/30 rear. and with those spacers shave rear and roll front
Old Jul 20, 2010 | 07:21 PM
  #1299
Imnutz4jdm's Avatar
Imnutz4jdm
ok so i have my mind set on gettin some volk te37 18inch for my Is250 AWD
but i would love a crazy concave in the rear
what fitments and offsets shall i go with and yes i want to go staggered
because as i was told as long as the hight is the same all around i wont mess up the AWD system
Old Jul 20, 2010 | 10:43 PM
  #1300
Mv350's Avatar
Mv350
i really hope some one can help you out with awd. im not sure about offsets you guys deal with.
bump for help
Old Jul 21, 2010 | 02:52 PM
  #1301
Kybball#1's Avatar
Kybball#1
Default TE37's Could I make these fit??
So i have found these Volk TE37's:
19x8.5" +44
19x10.5 +22
Is it possible to make these fit on my IS350.
Old Jul 21, 2010 | 02:57 PM
  #1302
venZon's Avatar
venZon
The rears are a good size but the fronts will be sunk in. But yes they will easily fit with the right rubber.
235/35 and 255/35
Old Jul 21, 2010 | 03:00 PM
  #1303
datplayaz's Avatar
datplayaz
You'll definitely need to shave and possibly pull your rear fender, I have 19x10.5 +22 now and I needed a pull. But it's very much possible to make it fit, however the front is very weak compare to the rear.
Old Jul 21, 2010 | 03:03 PM
  #1304
Kybball#1's Avatar
Kybball#1
I dont want to do a ton of rear fender mods if i have to make them fit, its just a deal thats really hard to pass up.
Old Jul 21, 2010 | 03:18 PM
  #1305
Karlson's Avatar
Karlson
Wouldn't the rear look super aggressive and the fronts tucked in. The front offsets seem almost like OEM rim specs where everything is in the mid 40s.
