Will those wheels fit? START HERE.
Old Apr 12, 2015 | 12:33 AM
  #5161
miketranis's Avatar
miketranis
dont buy it if you dont know the width and offset lol
Old Apr 13, 2015 | 06:04 PM
  #5162
langjaykev's Avatar
langjaykev
What tire size should I run ? 9.5 +22 for the rears, no camber. Thinking 255/35/19? I have shaved fenders for the rear, will that be cutting it close? Or should I just stick to 245/35/19?
I also have 8.5+22 up front planning to do 225/35/19.
Also will be lowered - Probably 1 from wheel to fender.
Any help would be great!
Old Apr 13, 2015 | 06:08 PM
  #5163
VTsuckah's Avatar
VTsuckah
Originally Posted by Neu2lex
Looking at some wheels online ,
20x9 ET 25 fronts
20x10.5 ET 30 rears
'08 is350 H&R springs
Thoughts? Thanks
You'll be rubbing all around and bad.
Old Apr 13, 2015 | 06:33 PM
  #5164
smokyis350's Avatar
smokyis350
I would stick to 245/30/19 on the rear. The front 225/35/19 should be fine. Not certain.
Old Apr 13, 2015 | 09:32 PM
  #5165
Justind27's Avatar
Justind27
Langjay not knowing if the f is much different body wise from the reg is, I run 19x8.5 +23 245/35 (still has room to clear if lowered/spacer, 19x10 +24 275/35 with rolled fender (rubbed on bumps at higher than 40-50 mph speeds)
Old Apr 13, 2015 | 09:48 PM
  #5166
smokyis350's Avatar
smokyis350
Nice car, Justin. Just needs to go lower tho
Old Apr 14, 2015 | 08:23 AM
  #5167
Justind27's Avatar
Justind27
Thank you, it will be soon. I just pieced together a nitrous kit instead of figs arms/bushings/swift springs/tokico hts shocks/sikky bars n links
Old Apr 14, 2015 | 12:38 PM
  #5168
langjaykev's Avatar
langjaykev
Thanks Guys! Ill see what happens!
Old Apr 14, 2015 | 01:59 PM
  #5169
Nixcision's Avatar
Nixcision
Just thought I'd check in as my pics before lowering from last summer makes this seem like a tight fit.
I have an 09 is250 awd, running a 225/40/18 18x8.5 +35 square setup. I have a set of bc coilovers which I will install in about a week, lowering about 2.5".
Will I need to roll my fenders up front? I'm confident that the rear will be fine as it is still quite tucked as it is. I am worried about that inside lip of the front fenders (top of the wheel well) digging into my tires.
I am on my winter wheels (still) until I do this next week.
Thanks!
Old Apr 15, 2015 | 06:34 AM
  #5170
Srt250's Avatar
Srt250
20x9+30 on a 225/35/20 and 20x10.5+35 on a 245/35/20 lowered on H&Rs will I need to roll my fenders?
Old Apr 15, 2015 | 12:19 PM
  #5171
dbuch07's Avatar
dbuch07
Default help
searched through multiple different pages found no luck. I might of missed this but oh well. I am looking at purchasing 19x8.5 wheels, what offset range should I look to stay in, typically not great with expertise on wheel fitment? Also what tire size would you recommend as I am lowered about 1.75" or so, I would not like to roll my fenders if possible at all.
Old Apr 15, 2015 | 03:27 PM
  #5172
IS2Fizzle's Avatar
IS2Fizzle
You'll be fine running 9.5 +22 in the rear with no camber. I'm running 10.5 +22 in the rear shaved and dropped on coils about 23.5 cm measuring from ground to the fender. I'm running 235/35 in the rear. I'm running 9.5 in the front with 225/35. And that's rolled, slight pull, and bumper tab relocated.
Old Apr 15, 2015 | 04:05 PM
  #5173
smokyis350's Avatar
smokyis350
When you guys same bumper tab relocated, are you guys talking about the headlight brackets?
So I rubbed a giant hole in the fender line now I am rubbing the steel part of the headlight brackets.
Old Apr 16, 2015 | 10:38 AM
  #5174
tboy620's Avatar
tboy620
Hi everyone, I'm new to this forum and would like some advice.
I have an 07 IS250AWD running 18X8 on 225/40/18 all round currently. I want to get a set of TE37 18X9 +25. I would run those on 225/40.18 F and 255/40/18 R. My question is will they fit on stock height without rubbing? And whether I'd absolutely have to roll/pull the fenders?
Old Apr 16, 2015 | 10:57 AM
  #5175
Nixcision's Avatar
Nixcision
Being that you're AWD (like me) its actually not the best idea to run a staggered setup (bigger in the back) as it isn't good for your drivetrain. Its always safe to have a square setup, same tire size and rim size all around.
Some people have done the staggered setups on their AWD's by calculating sizes so its the same rolling diameter front and back, but in the long run, a lot of the feedback has come down to regretting doing it in the first place. It can be done, but you run the risk of putting extra/premature wear on your vehicle.
You can run an aggressive setup by all means, but just keep a square setup if possible. (e.x. 225/40/18 Front and Rear, same rims all around)
Just my $0.02
