Will those wheels fit? START HERE.
Old Jan 30, 2014 | 12:21 PM
  #4876
panda_ek9's Avatar
panda_ek9
Originally Posted by Deegee
Is it safe to say that the rear wheels would look funny with a higher offset than the fronts?
For example, my vendor recommended i run 18x9.5 +22F and 18x10.5 +30R to eliminate tire stretch of going with a +22 all around. I'll need atleast a 3-5MM spacer in the front to clear the factory IS350 brakes which would make the offset around +17F.
Looking at Varrstoen ES7 style...
Hey bro be careful with these wheels and those offsets.. I have an is350 running es5 19x9.5 +22 19x10.5 +20 with a 2in drop all around and I rub everywhere even with bumper tab relocating and fender roll and pull.. Its frustrating I'm about to sell these wheels
Old Jan 30, 2014 | 12:28 PM
  #4877
dannyboy26's Avatar
dannyboy26
Did you remove your fender liners? Thats the only place I rub and just gonna cut them this weekend and spray some rhino bed liner in there to help protect from elements... If I still rub will consider some negative camber later on but as of now will just do some camber on my rear wheels
Old Jan 30, 2014 | 12:31 PM
  #4878
dannyboy26's Avatar
dannyboy26
Originally Posted by busychild
I have a 2008 IS350, currently staggered on the OEM 18'S. I have a set if 17x8, +35 offset Enkei RPF1's I would like to use.
I would like to use these wheels with 235/45 tires all around.
Any issues with rubbing it tire size? Need to get them this weekend.
You are pretty much running stock size cept for the offset which will look flush on your car, and no worries on rubbing you will be good even if you drop it
Old Jan 31, 2014 | 07:07 AM
  #4879
busychild's Avatar
busychild
Best news!
Old Feb 1, 2014 | 11:52 AM
  #4880
ndk83's Avatar
ndk83
new specs:
F:19x9.5+15 R: 19x10.5+18
will these fit w no probs?
my old specs were F:19x8.5+20 and R:19x8.5+15, so i had done the recommended fender roll, and hammered the fender tab upwards as it was eating my tire, then it would only rub on dips and not really scrape any rubber off my wheel. I have BC coils set to the stiffest setting. Ill be using the same tire size 225/35 and 255/30. My drop is 1.25 finger gap. No camber arms, and id rather not want to get them
Im concerned about the front (as i fit the rear and there seems to be enough clearance so it doesnt touch the rim. see photo below)
Would my new front rim size be a problem? No 215 tires available here
Here is how the new rears look to give u an idea of the wheel gap
Old Feb 2, 2014 | 08:47 AM
  #4881
avinad's Avatar
avinad
What's up. I'm looking for a good setup for daily driving. I am going to be on BC coils until I go air. What is a good wheel setup that would be good where I can still carry passengers? I'm planing to be rolling on 19" and be lowered just up to the top of the tire
Was thinking either 19x9/9.5 in front and 19x10/10.5 in rear. Anyone have suggestions
Old Feb 2, 2014 | 09:14 AM
  #4882
Sportskid1's Avatar
Sportskid1
Looking to run a square setup on my 08 is350 for track days. 18X8 (+45) wheels all around with 245/40/18's. Lowered about 2" (Finger gap). Really don't want to modify any fenders. Any issues with the front tires?
Old Feb 3, 2014 | 09:24 AM
  #4883
Deegee's Avatar
Deegee
Hey man, alot of it depends on your tires too. What tires are you running with this setup?
I really don't care if I rub the liners, my car has been slammed for a very long time with stock 18's and after a month of being slammed i don't hear any rubbing at all unless I hit dips going fast and thats only hitting the liners.
Now, if your talking about rubbing against metal thats another story.
Old Feb 3, 2014 | 02:24 PM
  #4884
Deegee's Avatar
Deegee
So I'm looking at 19's now with the following specs;
19x8.5 +17 and 19x9.5 +20
My car at the moment has no finger gap in the rear and maybe 1-2 finger in the front, I plan on running low but not slammed. What tire sizes are recommended? Again, I don't mind tiny stretch.
EDIT: Lets just say I'll be slammed to make it easier, So would 225/35 and 235/35 be ideal or would that be too much tire?
Old Feb 3, 2014 | 04:07 PM
  #4885
Tphotisane's Avatar
Tphotisane
Would Varrstoen ES2 19x9.5 19x10.5 offset 30 clear the 09 IS250 stock brakes ?
Old Feb 3, 2014 | 05:13 PM
  #4886
Deegee's Avatar
Deegee
Absolutely
Old Feb 3, 2014 | 07:16 PM
  #4887
static250's Avatar
static250
I would do a 225/35 and a 245/35
Old Feb 3, 2014 | 07:21 PM
  #4888
Deegee's Avatar
Deegee
Wouldn't 245 be too much tire or is that a more narrow tire? excuse my ignorance :/
Old Feb 3, 2014 | 08:35 PM
  #4889
static250's Avatar
static250
I run a 245/35 on my 11+25 and have ran it on a 10.5-+30 also
Old Feb 3, 2014 | 09:09 PM
  #4890
Deegee's Avatar
Deegee
So your saying on a 9.5 it wont even be stretched and should be a perfect fit going with 245 in the rear?
