Will those wheels fit? START HERE.
Old 03-27-19, 11:46 PM
  #5626
Kaufy19
Kaufy19's Avatar
Looking to get a couple good inputs here. Driving a 2012 IS250 AWD and looking at buying 19”x8.5” +35 offset rims with 235/35/19 tires for the front and 19”x9.5” +40 offset rims with 265/30/19 tires. Not lowering right away and was hoping to get some input on that.
Thanks
Old 03-27-19, 11:56 PM
  #5627
DPer4mance
DPer4mance's Avatar
Thanks
They will fit without any issues. Just not sure those different tire sizes work on an AWD. As far as I know an AWD needs equal diameter tires on all 4 corners, but I'm not sure. We don't have AWD's in Europe so never really looked into it. Maybe some guys with AWD's can tell you for sure.
Old 03-28-19, 05:57 AM
  #5628
sm1ke
sm1ke's Avatar
Yep, on AWD cars, the diameter of the front wheels should be as close to the diameter of the rear wheels as possible. I think most go with the rule that a 3% difference in diameter between front and rear is the absolute most you can get away with, but I'm not sure why. I ran staggered wheels that had less than 2% difference on my AWD and had no issues.
Old 03-31-19, 08:07 PM
  #5629
flyguy616
flyguy616's Avatar
I’m thinking about getting wheels the the spec 19x9.5 +22/ 19x10.5 +22 but don’t know about tires and if they will even fit. Does anyone know if they will fit and what size tires might work. The car is a 2011 and will be on coilover.
Old 04-01-19, 08:47 AM
  #5630
Petet
Petet's Avatar
Looking into purchasing new wheels. Probably going to stay with 18’s. I’m interested in a set of KMC KM703 18x8.5 / 18x9.5 35 offset for both. From what I have read there shouldn’t be a problem with fitting. But I really like the look of the deeper wheel in the rear. How do I figure out how to get this look ? Thanks to whoever owns the car in the pic.
Old 04-04-19, 05:56 PM
  #5631
Petet
Petet's Avatar
Default Offset
I have read so many old pages and think I know what I want for rims. But now I have found different offset options. What is the most offset I can go with in the rear without doing any mods. I want 18x9.5 was thinking of +35 with a 275-35 tire. Would a +20-+30 also fit ? I’m currently stock height probably going to do f sport springs when I do rear struts this summer. Thanks for any help there’s just so much info and options.
Old 04-20-19, 03:50 PM
  #5632
LouisV
LouisV's Avatar
wrong forum
Old 05-01-19, 02:58 PM
  #5633
BXIS250
BXIS250's Avatar
Hey guys, first post here.
I'm looking to get some input here as I'm new to this car.
I want these wheels, Japan Racing JR11's.
https://www.customwheeloffset.com/wh...cing-coilovers
However, I want a flush setup, not a tucked. I definitely want 19 inch and the deep look at the rear and slightly noticeable stretched tires all round and that fat *** and wide tires look at the rear.
What would be the maximum width I can go at the rear without rubbing and at the front without grinding against the wishbone?
Any help would be much appreciated.
Thank you.
Old 06-12-19, 11:41 AM
  #5634
YSL
YSL's Avatar
225/40R18 on 18x8.5 +35 offset (possibly run 18x9.5 +35 with a 225/40?)
255/40R18 on 18x9.5 +35 offset (also thinking maybe 245/40?)
Anyone on here run these specs on their 2IS? I've seen a couple pictures floating around but none of them say if they rubbed or not. I'm dropped on H&R Lowering springs too. Any help would be great!
L350XIS (08-21-22)
Old 07-09-19, 03:29 PM
  #5635
maeveLexi
maeveLexi's Avatar
Does anyone know the offset of the stock wheels on a 2008 IS350? I'm trying to make the fronts poke and the rears flushed.
All I know is if I get spacers, 15mm on front will poke and 20mm on the rear will flush.
Now all I have to do is add numbers but I don't know the offset of the stock wheels.
Old 07-09-19, 03:32 PM
  #5636
YSL
YSL's Avatar
Should be 45 offset front and 50 offset rear for stock wheels. 15mm front and 20mm rear should make the wheels sit pretty flush.
maeveLexi (07-22-19)
Old 07-09-19, 05:10 PM
  #5637
primavera
primavera's Avatar
Stock 8.0 and 8.5 inch wheels with 15mm front and 25mm on back will make it flush with the fenders.
https://www.clublexus.com/forums/is-...d-h-and-r.html
Old 07-12-19, 04:57 PM
  #5638
DrDDay
DrDDay's Avatar
I currently have a 1st gen IS300 with a front brake conversion from an IS350. I am looking at wheels for the vehicle and I have found a nice set of BBS RGRs. They are 18x7.5 +45.
My concern is if they will fit over the larger IS350 calipers. I have looked far and wide, but I haven't seen a 2G or 3G IS350 with 18in RGRs.
Old 07-18-19, 11:45 AM
  #5639
ricbsw
ricbsw's Avatar
Lost of info I tried the search function with minimal luck with my particular question.
Looking to buy the following wheels sizes, I need to know will they fit and any tire size recommendations for this size wheel to minimize rubbing and avoid rolling the fender. I have a 2012 IS250 rwd
19x8.5 35et
19x9.5 35et
Not lowered at the moment, but more than likely I will get coilovers, but if you are running springs and a similar wheel set up please let me know what lowering springs you are running.
Thanks a bunch for any info, this is my first post
Old 07-19-19, 09:43 AM
  #5640
NinjaSocks
NinjaSocks's Avatar
ricbsw (07-25-19)
Quick Reply: Will those wheels fit? START HERE.
