Will those wheels fit? START HERE.
Old Nov 19, 2013 | 03:25 PM
  #4801
Lex_Giorgio's Avatar
Lex_Giorgio
What are the specs that I need to have in order to fit LFA replica wheels on a 2010 IS250 RWD?
I found wheels with this spec, but I'm not sure if they will fit:
18 x 8
+38 offset
60.1 Center bore
5 x 114.3
Thanks!
Old Nov 19, 2013 | 04:03 PM
  #4802
IStnr's Avatar
IStnr
so, i finally pulled a front wheel off today that just wouldn't hold air any longer and didn't' see anything in the tire…figured it was a mild bend i could detect on the outside. turns out that the lip on the inner side has a good ~1" long crack on it.
'07 IS 350 sport package (~0.4" front drop?) currently running:
19x8 +40 235/35 w/10mm spacers
19x9.5 +40 275/30
i love my fitment in the back but would like to bring the front out another 5mm ideally (switch to a 15mm spacer essentially). however, I'm just being picky there and wouldn't ever bother changing the spacers. however, my other front rim is curbed, so i was considering on using this opportunity to get the different offsets on the front to get rid of the spacers completely (incorrectly thinking +25 was the other option). however, it's +20 or +40…and no 8.5" or 9" width available.
is a 19x8 +20 too much for the front? i want the tire to line up with the fender without protruding past it AT ALL (better to be slightly in than out). for a reference, i would not like the rear if it came out even another 5 mm, and i know others consider a flush setup in the rear much more aggressive than my current 9.5" wide +40 mm. of course, i'm not lowered in the back and have little camber to help. it's obviously a little different story in the front with a bit more camber, so i generaly look to the center of the rim to examine flushness there.
when i put the stockers back on later this week i will do a quick experiment with the remaining 19x8 +40 rim and double up my 10 mm spacers. however, i won't really be able to accurately access any rubbing of any sort with that…not with any conclusiveness at least.
i'd really appreciate any insight the wheel experts have for me!
Old Nov 23, 2013 | 11:30 PM
  #4803
SD.IS's Avatar
SD.IS
Has anyone here tried running 9.5 + 2/ 10.5 +7 on our cars before?
I want to know how they will sit once aired down on our cars.
Old Nov 24, 2013 | 04:24 PM
  #4804
Heckler's Avatar
Heckler
Looking at a set of wheels:
F - 19x9.5 35 offset
R - 19x10.5 35 offset
Lowered - little or no gap between tire and fender. Rears are already rolled. I want to make sure these will fit and what additional fender mods (if any) may be required.
Thanks!
Old Nov 25, 2013 | 11:27 AM
  #4805
510to808's Avatar
510to808
At stock height wondering will these wheels fit and what size tires do you recommend ?
front: 18x8.5 5x114.3 D.D. 35 73.1 2.0
rear:18x9.5 5x114.3 D.D. 40 73.1 3.0
Old Nov 25, 2013 | 11:39 AM
  #4806
killnN00bs's Avatar
killnN00bs
so I got the csl 5.5 concept ones in
Color Matte Silver Machined
Offset +36
Size 19X9
C1007 1990 36 55 MBK-BK
Bolt Pattern 5x114.3
can I run f sport springs without rubbing anywhere?
im running 19x9x235 in front and 265 in back
Old Nov 25, 2013 | 12:43 PM
  #4807
e46m3lol's Avatar
e46m3lol
That is a pretty conservative offset so you'll be fine without running into any rubbing issues.
You can run the stock tire sizes which are 225/40/18 and 255/40/18
Old Nov 25, 2013 | 07:38 PM
  #4808
Stevenhy92's Avatar
Stevenhy92
I'm going to be running 19x9 +13 not sure on tire size up front with my bag over coil setup. will I need camber kits for the fronts? i'm also doing 19x10 +18 on the rear but i heard ill only need it for the fronts. just trying to get more opinions.
Old Nov 25, 2013 | 09:10 PM
  #4809
static250's Avatar
static250
I would suggest front ball joints to adjust in some neg camber. As for the rear you will need camber arms and a mild pull depending on tire size.
Old Nov 25, 2013 | 09:13 PM
  #4810
static250's Avatar
static250
Thanks!
This particular setup I would do a 225/35 and 245/35 setup u can even get away with a 255/35 or a 265/30 on the rear. You will need to relocate front bumper tab and run about -2.5 to -3 deg of camber in the rear. Hope this helps
Old Nov 26, 2013 | 10:56 AM
  #4811
jcheng's Avatar
jcheng
Going to be running a set of NT03s from my old EVO. The setup is 18x9.5 +40 all around.
I do not plan lowering the car because of the horrible road conditions and my driveway has a very weird curb so it's not worth the trouble.
So my question is, would running 225/40 or even 235/40 cause any rubbing issues or any modifications needed?
Old Nov 26, 2013 | 12:14 PM
  #4812
510to808's Avatar
510to808
but if i decide to get cilovers what size tires do i need to go
Old Nov 26, 2013 | 12:33 PM
  #4813
e46m3lol's Avatar
e46m3lol
You'll still be fine even if you decide to lower it on coilovers. You may run into inner tire clearance on the 255 if you decide to slam it but you'll be fine with just a conservative drop.
Old Nov 26, 2013 | 01:00 PM
  #4814
Galvez's Avatar
Galvez
Here is what I plan on running. 19x8.5 +15 with 225 and 19x10 +15 with a 255. Im gonna roll fenders as well. Is this set up ok? Or should I go with a more narrow tire? Btw im on megan ez coils. Please guys give me your input. Thanks
Old Nov 26, 2013 | 02:55 PM
  #4815
e46m3lol's Avatar
e46m3lol
Haven't had any experience with 19" wheels but based off my 18x9.5 et12 rear wheels you'll have to run a narrower rear tire. This is a 245/40/18 and it sits perfectly and I have rolled and slightly pulled fenders.
