bluetooth question
Old Mar 11, 2010 | 12:42 PM
wkw84's Avatar
wkw84
CL Folding 1,000,000
Default bluetooth question
is there a way to use the bluetooth for anything besides just using it for the phone? like using it to stream music from my phone (Blackberry tour 9630). thanks
06isDriver's Avatar
06isDriver
not that I'm aware of
Old Mar 11, 2010 | 03:01 PM
HeartmyIS's Avatar
HeartmyIS
Yes, I use it to play music from my iphone =)
Once you've connected your phone to your car
You need to get to the option where it says BT-A: Bluetooth Audio.
Old Mar 11, 2010 | 04:40 PM
Kurtz's Avatar
Kurtz
This might be a change in 2010 models- I'd have sworn I've seen previous threads (with pre-10 nav systems) stating there was no A2DP profile on the system (meaning no streaming music)
Old Mar 11, 2010 | 04:42 PM
HeartmyIS's Avatar
HeartmyIS
^Oops, I didn't realize the OP was asking about 09'- models.
Old Mar 11, 2010 | 04:48 PM
ennjay's Avatar
ennjay
I wonder if it's possible with a firmware update? I mean the technology is there, but needs to be written...
I own a 06 is250 with Nav and I think that would be an awesome feature to stream AD2P signal and get pandora. For now I use the Aux input which isnt so bad supppose.
Old Mar 11, 2010 | 05:33 PM
fknISC808's Avatar
fknISC808
this post is more so just for info. In my 2010 IS-C I am able to upload my contacts to Nav via BT, listen to pandora or music on my SD card and control it via steering wheel. I have a mytouch3g
Old Mar 11, 2010 | 06:21 PM
Kurtz's Avatar
Kurtz
Pretty sure the technology isn't there.
06-09 has a Gen V nav system. 2010 is a Gen VI
Old Mar 12, 2010 | 06:23 AM
Bichon's Avatar
Bichon
True. The 06-09 only have the handsfree and object push bluetooth profiles.
Old Mar 24, 2010 | 11:35 AM
wkw84's Avatar
wkw84
booo.. thank you all for getting back to me though!
Old Mar 24, 2010 | 12:11 PM
EJC's Avatar
EJC
I have it on my '10 IS, it was not on my '07
Old Mar 24, 2010 | 12:58 PM
LyleBeach's Avatar
LyleBeach
It's not really all that though...
It does not display Artist, Album, or Song information while playing music over bluetooth.
Old Mar 24, 2010 | 01:08 PM
kslater's Avatar
kslater
I have a my touch 3g also. What update are u running because I cant a2dp or upload contacts via BT. Help me?
Old Mar 24, 2010 | 01:30 PM
EJC's Avatar
EJC
I'm not bothering w/ it.
I picked up a 16gb USB Stick on Amazon for $32 and stuffed it w/ music
I just plugged it in to the USB jack and leave it.
Old Mar 24, 2010 | 02:02 PM
fknISC808's Avatar
fknISC808
I havent done any update. I paired my phone, under the phone feature you can upload contacts via BT. I'll go test it out again and check the sequence and get back to you.
