Factory HID's
Old Mar 7, 2010 | 08:42 PM
IS250Slvr's Avatar
IS250Slvr
Default Factory HID's
Can someone tell me what color the factory HID kelvin is i am trying to match the fog lights to the headlights thanks im thinking they are 6000k but would like some input
Old Mar 7, 2010 | 08:54 PM
Jetfire's Avatar
Jetfire
Royale with cheese
4300k is factory.
6000k has a bit of blue tint to it.
Old Mar 7, 2010 | 08:58 PM
edgeucated's Avatar
edgeucated
i think all factory is 4300k. factory will never be 6000k
Old Mar 7, 2010 | 09:18 PM
eggwoll's Avatar
eggwoll
+1 couldn't have said it better myself
Old Mar 8, 2010 | 08:50 PM
wyee99's Avatar
wyee99
if I want to convert the 4300k to 6000k, will I just have to replace it with the bulb or do I have to purchase a whole new HID kit?
Old Mar 8, 2010 | 08:53 PM
IS250Slvr's Avatar
IS250Slvr
Originally Posted by Jetfire
4300k is factory.
Thanks i am trying to match the factory HID's with the fog lights to make them look sexy
Old Mar 8, 2010 | 09:05 PM
projectdna's Avatar
projectdna
if your 2is came equipped with HID's from the factory, all you will need to do is purchase and install a set of 6000k D4S bulbs.
if your 2is did not come equipped with HID's from the factory, you will need to buy an aftermarket HID kit.
check with CL vendors for your HID needs.
considering that the 2is oem HID's and fog lights are 4300k from the factory, and assuming that the factory HID's and fog lights have not been altered/changed, what do you need to match?
now, if your oem HID's or fog lights have been altered/changed to a different color temperature...
Old Mar 8, 2010 | 09:29 PM
brociouz's Avatar
brociouz
The OEM fogs are halogen bulbs in a reflector housing and I'd guess they're around the 3500K range, definitely not matching/4300K. Silverstar Ultra or PIAA Xtreme White bulbs for the fogs get you closer (check my thread here: https://www.clublexus.com/forums/is-...ng-lights.html).
For as close a match as possible, you'll need to get an HID conversion kit for your fogs with 4300K bulbs. If you're super ****, get a projector fog retrofit like me (I went with 6000K all around): https://www.clublexus.com/forums/is-...ml#post5295350
Old Mar 8, 2010 | 09:42 PM
projectdna's Avatar
projectdna
(bolded for emphasis)
oh? i thought they were closer or at 4300k, since 3000k is yellow and the 2is oem halogen fogs aren't as yellow as 3000k; maybe 3800k-4000k? just a guess...
i've also noticed that color temperature will not only vary with bulbs of the same size, but also halogen vs. HID, and even HID w/ and w/out projectors. but again, that's just based on personal observations.
imo, 5000k is the "sweet spot" as far as maximum light output and color temperature, but 6000k appears to be more popular (albeit better on color than light output) and my personal preference.
Old Mar 8, 2010 | 09:52 PM
brociouz's Avatar
brociouz
^ The halogen fogs could certainly be 3800K-4000K, all I know is they're nowhere near 4300K/matching. Even after switching to the Silverstar Ultras (rated at ~4100K, probably bogus), it was still a very noticeable difference. And you're right about halogen vs. HID, and projector vs. reflector, they all make a difference in the color.
5000K probably is the sweet spot between output and color, but I'm willing, like many, to sacrifice a little output for that awesome 6000K color. I'll never understand those 10000K people though.
Old May 11, 2010 | 01:24 PM
djbugz's Avatar
djbugz
I have a stupid question:
How would I know if my 2is came with HIDs from the factory?
I'd like to upgrade to 6k
Old May 11, 2010 | 01:36 PM
brociouz's Avatar
brociouz
When you start up your car the lights will go up and down (auto-leveling).
Old May 11, 2010 | 01:46 PM
djbugz's Avatar
djbugz
I think i have factory HIDs then!! =) AWESOME... 6k here i come.. Do you know the bulb model number? =) I love these forums.. you guys are great!!
Old May 11, 2010 | 01:54 PM
brociouz's Avatar
brociouz
D4S is the bulb type. Get Garax 6000K or Philips Ultinon if you want spend 3x as much for the brand name and maybe slightly better output (haven't seen them in person so can't comment).
Old May 11, 2010 | 04:22 PM
Willdb15's Avatar
Willdb15
How can i get my fogs looking yellow without tinting and without converting to hids. Although my car is already hid the fogs arent right?
