Factory Projector Len (HID VS Halogen) Difference
Old Mar 2, 2010 | 07:49 PM
BaBuJ's Avatar
BaBuJ
Default Factory Projector Len (HID VS Halogen) Difference
Hi all,
I am wondering if any of you know the difference (if any) b/w the projector headlight lens w/ factory HID vs the factory halogen? I am thinking to install HID to the IS250 and like to see if there's anything difference in terms of the lens and the type of bulbs (will I need the type of HID bulbs that has the small metal plate that blocks lights from reflecting at the wrong direction...)
thx
Old Mar 2, 2010 | 10:02 PM
brociouz's Avatar
brociouz
They are entirely different. Halogens use reflectors, HIDs use projectors, which you probably already know. You could get a straight conversion kit (H11) and use the reflectors with HID bulbs (lots of glare, no clean cutoff, "ghetto" style HIDs basically), or you could retrofit projectors, but it's a big project. Google/search it.
Old Mar 2, 2010 | 10:26 PM
GiantsFan's Avatar
GiantsFan
Doesnt the ISX50 with halogens come with projectors as well? I remember seeing a thread where someone showed a "before/after" pics and it showed a clear cut-off on the "before" pic ...
Old Mar 2, 2010 | 11:09 PM
JDKane527's Avatar
JDKane527
CL Folding 25,000
I can't tell the difference between any IS because they all have projectors haha. ES too the halogens have projectors. This is when they aren't on. At night when they are on the brightness is noticeable.
Old Mar 2, 2010 | 11:28 PM
brociouz's Avatar
brociouz
Hmmm, could of sworn I saw a 2IS with reflector lows, could be wrong though. The bulb will definitely be different from the OEM HIDs though, unless you do a D4S retrofit.
Old Mar 2, 2010 | 11:49 PM
kickin8's Avatar
kickin8
2IS/2RX/4RX
the one w/o HIDs got projectors too...you can tell the from the color difference / brightness
Old Mar 2, 2010 | 11:51 PM
GiantsFan's Avatar
GiantsFan
Ok, found the pic of halogen cut-off ... looks like projectors to me...
here is the thread by muzzman1
https://www.clublexus.com/forums/is-...-pictures.html
Old Mar 3, 2010 | 12:01 AM
brociouz's Avatar
brociouz
^ Yup, I stand corrected.
Old Mar 3, 2010 | 08:37 AM
xuningshen's Avatar
xuningshen
2is have never had reflector low beams, high beams/DRLs are reflector housings.
an HID kit on the non-hid projectors look just as good to me as the factory HIDs, same cut off and everything
true some projectors are better than others, like everybody loves s2k projectors with their crazy cut off, but i honestly can't tell a difference between a 2IS with after market HID ballast and a 2IS with stock HID ballasts and bulb swap, the only thing your missing out on is AFS
Old Mar 3, 2010 | 09:07 AM
DJSirkit13's Avatar
DJSirkit13
The lens on OEM HID projectors is more Clear than the halogen projector where the lens is more foggy I think thats the word im looking for.
Check this Out
https://www.clublexus.com/forums/is-...intensive.html
Old Mar 3, 2010 | 10:39 AM
svntwosix's Avatar
svntwosix
The link you provided is of someone who installed different projectors into his headlight to get that crazy color and cutoff.
Old Mar 3, 2010 | 10:51 AM
Bobby206's Avatar
Bobby206
I do not have factory HIDs but after installing the Volt 6k HID system I compared them to a friends factory HIDs and his cufoff is better.
Old Mar 4, 2010 | 12:12 PM
kevetard's Avatar
kevetard
yea i have a hid kit with halogen projectors..there a clear difference between this a clear difference between this and hid projectors with the beam pattern and cutoff....theres no after market route we can do that is fairly inexpensive to get hid projectors for this car other than a retrofit is there?
Old Mar 4, 2010 | 12:15 PM
BinaryJay's Avatar
BinaryJay
I thought all 2IS had HID, I guess I learned something today.
I never paid much attention to one with the lights on at night, but just passing them by on the street I saw projector lenses and made assumptions.
zuluzulu
RX - 3rd Gen (2010-2015)
Jun 20, 2017 06:33 AM
Chumacher
Oct 20, 2009 01:06 PM
Blizzy
Lighting
Aug 19, 2007 12:57 AM
brentweiss
Apr 14, 2006 05:59 AM
MoogieBoogie
Lighting
Feb 28, 2004 02:48 PM
