Steering Damper?
Old Nov 30, 2017 | 07:18 PM
  #496
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Originally Posted by MikeFig82
There is one listed in the classifieds right now.
His car already has it, so no worries.
Jeff
Old Dec 1, 2017 | 05:47 AM
  #497
jr4div2's Avatar
jr4div2
Yes, that's the one I was looking to buy and the seller was kind enough to show me Jeff's quote about it being included in the '12 ISX50C. Thanks
Old Dec 1, 2017 | 05:48 AM
  #498
jr4div2's Avatar
jr4div2
Jeff
Thanks, Jeff. You're always so helpful. We all appreciate it.
Old Jun 11, 2019 | 10:31 AM
  #499
metaleckz's Avatar
metaleckz
Less vibrations for sure!
Old Jun 12, 2019 | 10:32 AM
  #500
2013FSport's Avatar
2013FSport
An observation....
This is an inertia damper. Adding mass takes effort to get it into motion and/or stop it once in motion. That said the fact that some weigh the same but behave different is perhaps because one has the mass centralized in board while the other has it further out from the center yet they weigh the same. Possible?
There is the old quote; Objects in motion tend to stay motion.
As Jeff pointed out the 2011 up AWD get them but not sure if F-Sport did or not?
Old Jun 12, 2019 | 01:38 PM
  #501
Zmon's Avatar
Zmon
Originally Posted by 2013FSport
An observation....
I recall Jeff mentioning previously that the F-Sports don't have them unless they're AWD.
Old Jun 12, 2019 | 07:32 PM
  #502
2013FSport's Avatar
2013FSport
Thanks man. It seems the yoda/lexi gang made it tough to isolate F-Sport specific parts even using the VIN. That said the "where used" only brings up the AWD 2011 - 13, IDR the codes but GSE26 and another vs my GSE21L-AETLHA.
Old Oct 23, 2019 | 11:48 AM
  #503
SkyyzVodka's Avatar
SkyyzVodka
Default Ordered IS-F damper
Found the damper on eBay for $31
Sourced the screws from Toyota dealership for $3.50
I also have a perforated leather steering cover with blue stitching arriving in a couple weeks.
this should be a fun project lol
Old Dec 2, 2019 | 07:17 PM
  #504
davidbusta's Avatar
davidbusta
just install mine on my 2006 IS350. I immediately felt the difference. wasn't too heavy but definitely has its weight to it. the steering wheel doesn't have those little vibrations that it used to have. i didnt think the steering wheel vibrated too much before although i did feel a little bit of vibration. but now with the damper i just started realizing how much it really vibrated before since theres practically no vibration now. worth the install especially for $30. i got my 2012 ISF power steering ECU on the way. can't wait to get that installed as well
Old Dec 2, 2019 | 08:29 PM
  #505
2013FSport's Avatar
2013FSport
Apply dielectric grease to the pins when installing.... Corrosion resistance coupled with moisture protection.
Old Dec 3, 2019 | 01:09 AM
  #506
davidbusta's Avatar
davidbusta
wait why? What kind of corrosion can occur there? What moisture gets in there?
Old Dec 3, 2019 | 07:43 PM
  #507
2013FSport's Avatar
2013FSport
Reference is your steering ecu sitting under the battery. Ideally nothing gets to it, but this is for preventive measures!
Old Dec 3, 2019 | 07:48 PM
  #508
davidbusta's Avatar
davidbusta
Ohh okay, i thought that you went to talking about the damper. which is why i was very confused since you didn't specify which one you were talking about exactly. but now it makes sense, thank you for the heads up. ill definitely look into it!
Old Dec 4, 2019 | 11:22 AM
  #509
MikeFig82's Avatar
MikeFig82
Does anyone know the weight of the ISF paddle shifters?
Info found:
Shifters are about 107 grams for both.
Old Jul 15, 2020 | 11:05 AM
  #510
sinister2c's Avatar
sinister2c
Did a DIY Video on putting this damper in, 5 minutes to install.
