Steering Damper?
i've said this before and i'll say it again: If you're on a stock wheels/stock profile size tires/stock suspension/soft suspension you probably wont feel much...
BUT...if you're on 19's and up with a stiff suspension/setting you will immediately notice it and it really helps reduce the fatigue in the hands, wont feel its necessary to hold the steering wheel so tight.
I installed mine and I love it, I have coilovers and aftermarket rims with wider tires so maybe I can tell the difference more than those with stock setups.
My coilovers have pillowball mounts which transmit vibrations to the steering wheel, and the Damper helped alot get rid of some of those. Also when taking hard turns the effort that you have to put in is a little bit less.
Its so cheap that I dont see why nto get it. It can only do good to the car
just pull it out then you can disconnect the wires
installed. I don't feel a difference!!
not only that.. my ecu resetted!! so now my car feel a bit jerky now
. I will be driving down to LA tomorrow so, we'll see wussup. so far I'm disappointed tho.
Hey guys sorry to bring up an old thread. but the very first post says to get the IS-F damper. Is there a difference between the ISF damper or the one sewell has up for the 250s? Im gonna order tonight. Thanks
Edit:Okay i think i get it now. When the OP originally posted his thread sewell wasnt providing it for the 250s And they just started selling it as a kit with the screws for the 250s COrrect me if im wrong. Thanks
). oh well!! LOL that's life for ya.
