Power Window Problem
Old Feb 15, 2010 | 07:04 PM
simpsonn's Avatar
simpsonn
Default Power Window Problem
So I just finished hooking up the XM tuner last night and had to unplug the car battery to do so. So after plugging it back in, I go around and "fix" all of the power windows. They all fix as they should except when I get to the passenger window, the window will not roll down at all and the green light is still blinking on the window switch. The driver and both back windows worked, but the passenger will not. Any suggestions?
Old Feb 15, 2010 | 08:24 PM
iSuxeL's Avatar
iSuxeL
Are you trying to roll the window down from the driver switches? If so that won't work. You have to set the window from that switch. Roll it down about 2inches and then roll it back up while holding it for about 2secs then its set.
Old Feb 16, 2010 | 09:04 AM
simpsonn's Avatar
simpsonn
I'm rolling them down from each individual door...
scarface85
Apr 2, 2025 07:37 AM
kpkim01
Sep 25, 2019 11:00 AM
simplecar
RX - 1st Gen (1999-2003)
Sep 15, 2018 07:43 PM
xiaowen
Jun 5, 2012 11:57 AM
doverrx330
Aug 3, 2010 06:10 PM
