battery light is on!! help!!
Old Feb 12, 2010 | 09:53 AM
imran4u01's Avatar
imran4u01
Default battery light is on!! help!!
my battery light is on for some odd reason,
my battery was replaced about 3 weeks ago and was on before that and is still on
i went to 2 local shops by my house and got the battery and alternator and both shops said they were good, what else could the problem be guys???
they tried to see if they could pull up any codes and everything came clear
tried going to the dealer and they said they cant do anything since i have a aftermarket headunit and a soung system
any advise?
PS: thanks for the help out guys
Old Feb 12, 2010 | 11:09 AM
B16da9's Avatar
B16da9
I can tell you that just because they tested them it does not mean they are good. I had this problem with my Integra a long time ago. Autozone tested my alternator and they said it passed the test when it really did not. One sure fire way to know if your alternator is no good is to remove your negative battery wire while the engine is ideling. If the engine shuts off your alternator is shot.
Old Feb 12, 2010 | 11:20 AM
imran4u01's Avatar
imran4u01
ok thanks man ill try it out when i get off work
Bettaworld
May 3, 2017 01:23 AM
masboy
Mar 4, 2012 06:37 AM
Pogigreg
Dec 29, 2011 04:18 PM
OBEY414
Nov 21, 2011 02:12 PM
Andymi
Nov 25, 2001 02:29 PM
