Spacer question
Old Oct 14, 2009 | 08:18 PM
Wierdazndu's Avatar
Wierdazndu
Default Spacer question
Does anyone know for our IS if i put a 5mm hubcentric spacer on my fronts to clear BBK do i need extended studs? I wasnt sure cause its such a small spacer.
Old Oct 14, 2009 | 11:42 PM
projectdna's Avatar
projectdna
i believe for the ichiba 5mm spacers they come with longer studs.
http://www.ichibausa.com/5mmalwhsp7.html
Old Oct 15, 2009 | 01:19 AM
J250's Avatar
J250
If its only 5mm it'll be fine without extending the studs. If anything wider than yes you definitely need to replace them..
Old Oct 15, 2009 | 09:10 AM
Kevin.IS's Avatar
Kevin.IS
5mm you won't need it because there would still be enough threading. Extra studs wouldn't hurt, just to be on the safe side.
Old Oct 15, 2009 | 11:20 AM
ChrISF's Avatar
ChrISF
no you dont need extended studs for 5mm spacers....i've been running with 5mm spacers with stock studs for the past 3 months and i've had zero problems.
4play4dr
Suspension and Brakes
21
Jul 7, 2015 03:20 PM
Jzsicklexi
Jul 20, 2012 06:05 PM
stevenjai
Mar 29, 2012 07:21 PM
AtlantaVIP
Nov 15, 2011 11:43 AM
wongerZ
Jan 28, 2009 06:30 PM
