Staggered setup on AWD ! - The Mother Thread - !
#151
Question!
I am trying to run 19x9.5 +22 Front and 19x10.5 +22 rear on AWD IS250.
What size tires can I get?
225/35 Front and 245/40 Rear
or
225/40 Front and 255/35 Rear
or
235/35 Front and 255/30 Rear
or I was told that 235/35 Front and 265/30 Rear would work.
I want to make sure I don't **** up the AWD system as I can imagine it would cause issues. I do want a slight stretch, so the 235/275 combo everyone is running would be too much for me.
Thanks!
or
or
Thanks!
#152
^ 225/35/19 F and 255/30/19 R would be the optimal choice for your wheels. Besides, you're going to need some stretch to fit those wide wheels.
http://www.1010tires.com/tiresizecalculator.asp
^ is a good website to check the outer diameter between front and rear wheels to make sure the AWD system doesn't get screwed.
#154
So could I switch to 225/35 and 265/30 and still be ok?
I remember a better rolling diameter website than the 1010, but I can't find it.
#155
Would the above be OK. I have 19x8.5 and 19x10 with 235/35 and 275/30 right now. I had a lot of rubbing in front with the 235/35 at the height I want the car.
